  • Guests: 25
Bead (41)
Fumeaux (25)
04/26 Bead (41)
04/26 Fumeaux (25)
04/28 Steve Conner (46)
USB 3.0 Programming in VB (simple question regarding calling functions)
Linas
Sat Dec 31 2016, 10:45AM
Hello,
For the fun i try to write and test all USB 3.0 functions from D3xx library.
So far get number of devices and was able to open and get handle. Now i want to toggle GPIO to see how much speed i can get between transfers. Because in my original program if i can't get faster than 1ms between transfers ( very short ones ) I will use FT232 in MPSSE mode that can be connected directly to ARM.
Problem i am facing is something wrong with my call or definition of function, can any one spot the problem ?
In programming manual:
FT_STATUS FT_EnableGPIO(FT_HANDLE ftHandle, UINT32 u32Mask, UINT32 u32Dir)
in VB i have to declare it:
Private Declare Function FT_EnableGPIO Lib "C:\FTD3XX.dll" Alias "FT_EnableGPIO" (ByVal pftHandle As ULong, ByValMask As ULong, ByValDir As ULong) As Integer
And i call it like this:
Private ftHandle As Integer = 0
Private ftStatus As Integer = 0
Dim Flags As UInt32 = &H10
ftStatus = FT_Create(Index, Flags, ftHandle)
Sleep(1000)
Flags = 2
ftStatus = FT_EnableGPIO(ftHandle, Flags, Flags)
Note that i get correct FTHandle, so this is not a problem, problem arises than i call FT_EnableGPIO, debugger says:
1483181075 1143 FT0 Error
Does any one know how to fix this ? Millions Thanks :)
