  • Guests: 52
Bead (41)
Fumeaux (25)
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Homemade super-capacitors
Carbon_Rod
Sun Jul 19 2015, 10:43PM Print
Is there a better documented source of information regarding this process?
It seems a little unclear exactly what is being constructed.
Cheers,
Rod
Sat Aug 29 2015, 06:56AM
Yes, this is a real thing.
Since the original discovery of laser generated graphene people have been modifying old Lightscribe drives to do this.
In fact, a UV laser is even better and a simple X-Y setup can be made for less than £100.
See Marcel Lenormand's DIY etcher smile
One thing I did find is that even a small change (ie different substrate, electrolyte, etc) can massively impact the results.
I found that a good way to get started with supercaps is to use aquarium carbon (activated charcoal) and this isn't particularly expensive.
radiotech
Fri Sept 11 2015, 02:47PM
From the first video (excellent !) One part said, un ripping scouring pads
gives us fine iron wires.
Were those scouring pads stainless steel ?
hen918
Fri Sept 11 2015, 05:02PM
radiotech wrote ...
well, I've never heard of a iron scouring pad, that would be very bad idea. It must be stainless steel.
Ash Small
Fri Sept 11 2015, 06:30PM
hen918 wrote ...
hen918
Fri Sept 11 2015, 08:37PM
Ash Small wrote ...
hen918 wrote ...
I have some steel wool, however it isn't a pad, and it isn't iron.
I was thinking of a device for cleaning cookware, so I take your point.
Ash Small
Fri Sept 11 2015, 11:05PM
It's low carbon steel, so not very different to iron in it's characteristics. It does come in pads, like 'Brillo pads' but without the soap impregnation.
What I saw in the video looked like stainless, so I'd like some clarification of the principles as well.
radiotech
Sun Sept 13 2015, 07:05AM
How do know it is a super capacitor? The math at the end would work with
a storage battery, renamed as a 'supercap'.
1442127932 2463 FT172269 Tavis Supercap Calcs
Bored Chemist
Sun Sept 13 2015, 09:28AM
dV/dQ
radiotech
Sun Sept 13 2015, 06:19PM
The plastering mesh looks shiny, and it must interact with plaster in way that
maintains strength with destroying or corroding the metal.
Exact details of the alloy/coating would be good to know.
Also, does the sodium hydroxide go down through the carbon
and form two couples, one on the positive plate, and one on the negative ?
Given that the two electrodes are identical and separated by a porous insulator
the chemistry is two carbon surfaces in Sodium Hydroxide, or is at the metal
-carbon ?
After the initial current limited charge, what has happened to make
one plate more electro positive than the other?
This cycle is reversible obviously.
I picked up an old (real) book and flipped to Energy in Concentration Cells.
Not happy reading.
If this Tic-Tac battery is a copy of a commercial product, perhaps someone
could dig up a patent number. That might help. If they do make such a cell,
they wont tell anyone how.
