Registered Member #56
Well I was on ebay last week and found an opportunity to get >1kw of 808nm pump diodes (for pumping Nd:YAG for a high quality 1064nm beam, or possible a block of KTP or some other non linear optic for 532nm green)--in bare chip form.
So I managed to convince McFluffin go 30/70 hoping to sell most of them back off as bare dies (at the current going rates that would be ~$7k in profit) but we (well I) plan to mount somewhere between 1 and 20 of them and possibly pump a frankenstein ssy-1 laser for some colminated (abit not tem00) 1064nm beams.
In any case, to sell the dies individually I needed gel-paks, and since my dad works at a laser manufacture he has tons of them, with one catch---they already have 10 year old laser dies in them So he brought home ~100 lasers that have power from 10-40mw at 1550-800nm (no idea where, they aren't marked with anything that makes sense) and a bunch of very high speed photo diodes.
So I decided to practice mounting some diodes to prepare for the bars...
Note--This is the things I did correctly, I resanded the copper block at least 10 times over the course of the afternoon after I screwed up. About 5 hours of work went into it, I bet I could fo it again in 30 minutes. We shall see tomorrow.
I started by smashing a to-220 fet to remove the plastic, then hacksawed the copper substrate off at the bottom of the hole. Then I filed it down to be about the right shape. Then I sanded the edges with 120grit paper (just eyeballing the shape). Then used 320->2/0->5mil lapping film on the faces.
Then I put a dab of solder on it, and soldered a piece of .030" pcb stock on it (to give me a place to put the wire to the cathode of the die).
Then the fun part, I heated the whole mess up to ~130C, touched it with my flux pen, and started tinning. After I got a good tin I wiped 90% of the solder off, leaving a thin layer.
Then on goes a die...
And then the wire to the cathode...
And then turn of the hotplate, and rinse with IPA (very well, don't want any flux on that diode)
Sorry no pics of the assembly process, but I didn't have my microscope cam set up, nor did I have my capture card in the right computer.
Add 2v/100ma and viola, 30mw of IR light :) running at low power and high power
loking strait into the diode and area where I was working Can anyone figure out where the laser is in the last pic?
I will be posting often as things progress. I don't think this should go in the project thread as I am expecting comments/discussion and there is not a definant end to the project (yet)
Well the dies finally came
23 ~20w bars, and 18 ~50w ones
There were also ~20 copper mounts to solder them down to, and parts of a different mount (but I have found a way to modify them to work together without looking too much like it was built by a 16 y/old)
I am now almost ready to take over the world MUHAHAHAHA
Oh, and a full week and no responses... What is with you guys! No more pics until someone says something...
Registered Member #99
Neato!Are these bare laser diode chips we are talking?if so, kudos to you!Not an easy thing to do...Ive always wanted to try, but prohibitive costs of laser parts and lack of steady hands kept me from doing so...
Make sure to post some pcs of it lasing!20w ought to be nice... Matt
I have the correct googles, and will be doing most of the experiments under a video camera becuase it is too small to see with the naked eye and that whole problem of it being invisable.
I should point out now that these bars won't give a 'real' laser beam, it is actually going to look like a flat line that is made up from a bunch of small spots from each of the emitters in the bar.
That is why I hope use some of them to pump a Nd:YAG rod, as that will result in a decent single mode beam that can at least be focused down to a single spot. I have most of the parts to do this, except the 99% reflectance 1064nm mirror to use as the output coupler. I will try with another ~100% mirror first to at least prove that it is lasing, but I can't get very much power out of it that way.
Ideally I would use a l-fold cavity and have a block of KTP to double for a few wats of green, but that will require acess to a mill to mount everything.
The dies are slightly hydroscopic, however for short term that are fine out in the air. So long as you store them with a dessicant they will be fine.
BTW, those chips are HUGE compared to what I was mounting. One of those bars is a block of ~100 of the size bars I mounted the first time.
... wrote ...
Also those bars will need to be colimated before they become dangerous, unless you go putting your eyeball right up to one
Check ebay for the mirrors, also try Meredith Lasers( they sell this sorta stuff). If you can find a SSY-1 laser head, you may just need to modify it some for the diode bar pumping, but they usually run $$$, i once got one for 75$ on ebay, so keep looking...
My current plan is to use a ssy-1 (I have 3 as of now), but as it is the OC has way to low of a reflectance for me to be able to get it to lase as is, so I will need to get a correct one. For testing I can replace the OC with another HR, but that won't let very much light out being like 99.99% reflectance
I have been watching ebay extreenly carefully, but have not found what I am looking for. The problem is that what I need is not a very common optic, as most HR's are designed for flashlamp pumping and thus have a low reflectance, while I need a moderatly high (~99%) one. I have been e-mailing many different suppliers and have yet to find a sutable optic.
I will also need to find a way to cool the rod, as with ~150w going in it will need some pretty massive coolling
I have e-mailed casix directly with no response, however if anyone knows a distributer that will sell me a NDO0101-1064nm-98% in single unit quantities I am all ears (although I will admit that I have been swamped with homework and have not really been looking all that hard)
