  • Guests: 36
04/28 Steve Conner (46)
04/29 GODSFUSION (37)
04/29 Zajcek (37)
Little DRSSTC from zilipoper ;D
zilipoper
Fri Jan 17 2014, 12:16PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
hi coilers amazed
this is another of my project small DRSSTC
I use a full-bridge 50B60 igbt
I do not have OCD, PREDICTOR cheesey primary current over 300А suprised when the arc may up to 400A suprised in this coil did not explode none igbt cheesey
very often strike in the primary winding angry
constantly exploding capacitors in MMC amazed
this coil is so loud that the neighbors killing shades
1389960556 4152 FT0 Pqncdlzdgaw
1389960577 4152 FT0 Exzqhdj2rae
1389960599 4152 FT0 Dsc 5055
1389960623 4152 FT0 666
1389960644 4152 FT0 Dsc 5068
1389960667 4152 FT0 Dsc 5069
1389960688 4152 FT0 Dsc 5070
1389960712 4152 FT0 Dsc 5071
short video not at full power amazed Link2
zilipoper
Fri Jan 17 2014, 12:25PM
I apologize for the 2 post, could not upload photos ill
1389961264 4152 FT160457 65756
1389961344 4152 FT160457 77777
1389961394 4152 FT160457 88888
1389961458 4152 FT160457 9999
Fri Jan 17 2014, 01:10PM
You never seize to amaze me with those crude coils that pump out gigantic violent and scary arcs in only a way a Russian can do it.
Please give more details about your resonant frequencies, MMC capacitance etc.
zilipoper
Fri Jan 17 2014, 02:30PM
hAh thanks smile
Resonant frequency of 96 kHz
MMC 24nf Russian ceramics
secondary coil diameter 11cm
45cm long
small tor 8cm to 21cm
big tor 16cm to 52cm
Fri Jan 17 2014, 03:20PM
I could'nt agree more with Mads, your projects just... are amazing compared to how 'retro' they look xD
Sigurthr
Fri Jan 17 2014, 07:08PM
I saw this coil pop up on YouTube and it simply amazed me. You've outdone yourself again, Zil! Such raw power in that arc!
zilipoper
Fri Jan 17 2014, 08:39PM
thank you shades
it was still not at maximum power
it will soon be even angrier and more powerful crazier wink
Fri Jan 17 2014, 09:53PM
Wow, awesome!
You developed the single transistor tesla coil into a full bridge DRSSTC.
How does it behave at higher pulse rate? Or hard arcing at earth?
zilipoper
Sat Jan 18 2014, 12:49PM
vasil wrote ...
Wow, awesome!
it is quite normal for the coil
but mains wiring in the house begins to melt ill
Uspring
Sat Jan 18 2014, 01:08PM
That's an interesting design. You seem to have a huge primary inductance of about 110uH. This way you can store a lot of energy in the primary tank until it is dumped into the secondary when it is pulled into tune. This sudden discharge probably causes a lot of voltage in the secondary, so that flashovers become likely.
I guess you use long bursts (500us?) due to the slow current rampup.
Can you post a picture of your primary? Why do you have a toroid in the middle of the secondary?
