  • Guests: 27
05/04 Matthew T. (35)
05/04 Amrit Deshmukh (60)
05/05 Alexandre (32)
12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B
zilipoper
Fri Oct 21 2011, 04:44PM Print
zilipoper Registered Member #4152 Joined: Thu Oct 20 2011, 10:18PM
hi all
introduce to you the high-frequency VTTC! amazed
1319215307 4152 FT0 1
1319215315 4152 FT0 2
1319215323 4152 FT0 3
1319215331 4152 FT0 4
1319215347 4152 FT0 5
1319215378 4152 FT0 6
1319215394 4152 FT0 7
ScotchTapeLord
Sat Oct 22 2011, 01:37AM
I showed those videos to a friend the other day.
She thinks your bed sheet is awesome.
MRacerxdl
Sat Oct 22 2011, 03:44AM
OMG, These sparks looks more flames than sparks!
Very good work! Congrats :D
Phillip Slawinski
Sat Oct 22 2011, 12:13PM
Phillip Slawinski Registered Member #1732 Joined: Thu Oct 02 2008, 02:34PM
Excellent work! That's a very unique looking arc there! Looks like an arc you'd get from mains transformer.
Sat Oct 22 2011, 02:51PM
What do you use as a hf ground? My friend and I had some problems with the high frequency voltages travelling through mains when running similar "plasma flame" oscillators...
zilipoper
Sat Oct 22 2011, 03:36PM
Hi Dr. Kilovolt
it works not ground shades
Myke
Sat Oct 22 2011, 05:43PM
Ooooooo! Very nice HF flames! I've never seen a tube coil have flames that big before.
How is the secondary wound and what did you use to cover it? On the schematic, Bt is the representation of W?
zilipoper
Sat Oct 22 2011, 06:48PM
there high-voltage isolation coil cheesey
Goodchild
Sun Oct 23 2011, 07:49AM
Russians and there tubes... hehe
Very nice work. looks like one scary arc, almost like a candle, but with a really long flame!
BTW the music in the video sounds like it's from command and conquer.
Luceš
Sun Oct 23 2011, 01:13PM
Luceš Registered Member #4108 Joined: Sun Sept 25 2011, 11:43PM
I have seen your videos and your result are amazing!! I hope to someday fire my gu5b :D but right now its just sitting on the shelf collecting dust frown
