hi all introduce to you the high-frequency VTTC! amazed
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B ScotchTapeLord, Sat Oct 22 2011, 01:37AM
I showed those videos to a friend the other day. She thinks your bed sheet is awesome.
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B MRacerxdl, Sat Oct 22 2011, 03:44AM
OMG, These sparks looks more flames than sparks!
Very good work! Congrats :D
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B Phillip Slawinski, Sat Oct 22 2011, 12:13PM
Excellent work! That's a very unique looking arc there! Looks like an arc you'd get from mains transformer.
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B Dr. Dark Current, Sat Oct 22 2011, 02:51PM
What do you use as a hf ground? My friend and I had some problems with the high frequency voltages travelling through mains when running similar "plasma flame" oscillators...
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B zilipoper, Sat Oct 22 2011, 03:36PM
Hi Dr. Kilovolt it works not ground
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B Myke, Sat Oct 22 2011, 05:43PM
Ooooooo! Very nice HF flames! I've never seen a tube coil have flames that big before. How is the secondary wound and what did you use to cover it? On the schematic, Bt is the representation of W?
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B zilipoper, Sat Oct 22 2011, 06:48PM
there high-voltage isolation coil
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B Goodchild, Sun Oct 23 2011, 07:49AM
Russians and there tubes... hehe
Very nice work. looks like one scary arc, almost like a candle, but with a really long flame!
BTW the music in the video sounds like it's from command and conquer.
Re: 12-20MHz Big HF VTTC 3kW. VACUUM TUBE GU-5B Luceš, Sun Oct 23 2011, 01:13PM
I have seen your videos and your result are amazing!! I hope to someday fire my gu5b :D but right now its just sitting on the shelf collecting dust
