  • Guests: 23
Matthew T. (35)
Amrit Deshmukh (60)
05/05 Alexandre (32)
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
Need help with the STM32F4-Discovery board...
Inducktion
Sat Oct 15 2011, 12:31AM Print
I recently acquired this dev board from ST, and I haven't the foggiest idea where to begin with it...
I do have two goals though, and, I perfectly realize it's overkill for the job I have in mind, but I would like to make a Li-ion/NiCd battery charger with it...
I know you need C++ to program it, but other than that, this thing might as well be from Mars as far as I'm concerned.
RickR
Sat Oct 15 2011, 03:37AM
RickR Registered Member #93 Joined: Thu Feb 09 2006, 04:11PM
Here's an IDE for the STM32F4: Atollic Website
I haven't used it at all for the F4, but I did compile a test program for the STM32F103RE evaluation board. They claim the free download version for the F4 version only supports C, but it seems to keep making reference in the IDE to C++.
CodeSourcery has command line-driven tools that I believe will work for the F4: CodeSourcery Site
I'm just getting started with the F4 also.
You might find this STMicroelectronics link useful also: STMicro Site Click on Design Support.
Just a bit more:Reference (choose Resources) The >1300 page reference manual can be found here.
This ought to help you get started.
Rick
Pinky's Brain
Sat Oct 15 2011, 03:55PM
IMO C++ is not the language to program uCs, unless you just use the C++ compiler to have // comments ... that's fine.
A macro assembler is fine too.
Linas
Sat Nov 12 2011, 05:18PM
does any one tried to connect lcd to f4 board ?
i have working code for stm32f103 mcu, but still no luck adapting code for st32f407mcu.
only part witch is left is GPIO initialize function, if some one can help me with that i even could pay neutral
(since i spend more than 20h just by doing that, and i am getting headache from all of this unsuccessful programing)
1321118307 1143 FT126188 P1010863
Thu Feb 09 2012, 02:55AM
Hey! i just noticed this thread, i too am using a Discovery board from ST, the STM32L!
im using the "L" sereis but id like to do optical flow on one of the "F" chips from the MS kinnect. im still trying to figure out how to use a "SLAM" model for robot real time mapping.
how many of us are there here on the forum?
if i buy the chips alone and try to attch them to my own mainboard, does anyone know what code is needed for debug and usb connectivity? I know the need some low level code first to start working. There are two chips, the target and then the USB handler IC...
Carbon_Rod
Thu Feb 09 2012, 04:40AM
CodeSourcery is pretty much a waste of time, and a sleazy ploy to get around the GPL.
Think about the most unoptimized version of the gcc you can imagine.
The gcc is a great compiler, but almost all the board support packages and documentation will be for the over priced Codewarrior IDE/compiler, or horrid Raisonance/Cosmic compilers.
You will need a JTAG programmer if the board did not come with a USB/Serial bootloader programmed on chip. If you can get Uboot working it gets a little easier...
So you think everything is ready to go? Nope, the uC/OS RTOS for the M3 series they often bundle is unstable garbage. This company does not give a bean about other peoples time... smile
Fri Feb 10 2012, 06:32PM
im trying to get a PID loop running in C on my STM32L... im finding a lot of examples, but i have no idea how good (or poor) they are.
Carbon_Rod
Sat Feb 11 2012, 08:20AM
In general your Kalman filter is a good solution:
Fuzzy logic performance is also fine for low CPU power systems:
However, it is always advisable to have set limits that override your control loop.
i.e. If the system behaves abnormally than default to a state known to be safe to people, and then the craft.
Sat Feb 11 2012, 02:43PM
Don't Keil or IAR have a free compiler that targets the STM32? I think the code size is limited, but it turns out enough for most hobby projects.
Carbon_Rod
Sat Feb 11 2012, 11:12PM
If your STM32F4DISCOVERY has the same model STM32F407VGT6 chip:
Information about the Ubuntu/linux based boot loader (or bypass using factory rom):
Full gcc cross compiler on MacOSX and Ubuntu/Linux:
Perhaps a small virtual machine for STM32 development with an update and build script would be helpful to a few people. As I find it helps to keep your cross-compiler development environments isolated and version locked to prevent random build environment problems.
cheers,
