  • Guests: 27
kg7bz (68)
steve516 (31)
05/16 kg7bz (68)
05/16 steve516 (31)
05/17 Finn Hammer (72)
High voltage probe for O-scope, 2 of 2, ( FABRICATION ).
1 2 3 4  last
Mon Sept 26 2011, 08:34AM Print
This thread will be dedicated to the fabrication and operation of the final probe design. Any replies should be with that understanding of intent and the normal project thread rules. All other comments, criticism and suggestions should be made to this thread:
Link2 High Voltage probe for O-scope, 1 of 2, ( DEVELOPMENT ).
(Compensation circuits have been posted on the "Development" thread.)
Otherwise Please comment!
Background info:
Sam Goldwasser's HV probe page... Link2
1315101988 2431 FT107837 Mdlt
Marco Denicolai's explanation of his 20 liter water HV probe (600kV).
[Note what i have highlighted in green.]
His PDF is here:
Marco's tesla and thesis site: Link2
Background Info End.
These next few pics show the construction of what i call the "High Voltage RC Element", this device is a SSX39 MG resistor,
125 Mohms in parallel with a coaxial 4.9-5.2 pF oil capacitor, both are meant to withstand 14 kV. 3 of these "elements" will be in series to obtain a 42 kV probe of 375 Mohms, at 1.5 to 1.7 pF. I just pray the field distrubution and capacitence is enough, the Northstars have 10 pF for a similar spec'ed probe. The bottom most plate is insulated from the resistor body, as the voltage drop beneath it is 800 volts less then the plate. This probe will be food oil filled and have a 10,000:1 division ratio.
1317024335 2431 FT107837 Progress
Sheet metal and copper ring.
1317024336 2431 FT107837 Rcids
Plates of steel and copper soldered and epoxied, then attatched as per the FEMM model for field distrubution.
1317024336 2431 FT107837 Rchv
Temporary hot glue mock up to test fit and funtion, this will be redone in oil proof epoxy soon.
1317024336 2431 FT107837 Rcinhand
A single HV RC element seen here in my hand.
1315101988 2431 FT107837 Platev
The resistor's V drop is linearized with the cap plates, and grading rings.
1317024336 2431 FT107837 Zoey
Zoey, best dog ever, on quality control.
1310768252 2431 FT0 Hvdivb
Insulator is acrylic should be good for 50kV+
[Gen 5, Type 3, Mod 6, Rev J, Ver 3.0, Attempt 12]
Final schematic, as it will be built in the next 7-10 days.
1317710412 2431 FT124946 Sp32circuit
C5 should be variable from 294 pF to 319pF, which will allow an oscope with 7-30pF internal capacity to be compensated.
The Ross Engineering, NorthStars, and the patent, as well as my probe all have one adjustment, to calibrate/compensate. This is a significant advantage over the 5 or more pots and trimmers the Tek p601(3,4,5)'s had.
1317776096 2431 FT1630 Drain
Oil Drain, and bottom end of the HV section.
More to come soon!
Sat Oct 01 2011, 05:16PM
I used this cheap circuit predrilled stuff but it was so weak, while making the piece i needed, it broke apart in my fingers. Ill need to use the real FR4 circuit board stuff then, its hard to cut though.
1317489409 2431 FT124946 Fr4needed
Tue Oct 04 2011, 06:40AM
[Gen 5, Type 3, Mod 60, Rev J, Ver 3.0, Attempt 12]
Mattski
Tue Oct 04 2011, 03:57PM
Is that 50 Ohm resistor actually part of the BNC connector? I would expect the connector to just have some stray capacitance and no resistance.
Tue Oct 04 2011, 04:10PM
Mattski wrote ...
Im going to add the resistor and capacitor, very close the the BNC connector, the connector is just the common straight through type.
When I add it, it will probably be a tube/bulge cover by heatshrink tubing.
Mattski
Tue Oct 04 2011, 04:19PM
Ah I see, I had thought that you were modeling the effects of the connector as a resistor and capacitor.
Tue Oct 04 2011, 04:49PM
Mattski wrote ...
Nope. smile
I also want to make a 1 or 3 kV square wave calibrator at 1-10 kHz.
EDIT new work :
Oil drain.
Thu Oct 13 2011, 12:51AM
New method for removing the silicone conformal coating from the caps, using MEK.
1318467176 2431 FT1630 Sam 0239
cap plates will be added shortly.
Thu Oct 13 2011, 04:05PM
Patrick,
" I also want to make a 1 or 3 kV square wave calibrator at 1-10 kHz."
How will you calibrate the calibrator?
Thu Oct 13 2011, 07:03PM
Sulaiman wrote ...
Patrick,
It only needs to have a high rise and fall time. IE, a square wave, like what is on the front of the oscilloscopes for compensation. (and serving the same purpose.)
The Tek, northstars, ross engineering and mine have pretty high accuracy from DC to 100Hz (like 0.1%) , yet the accuracy worsens towards 50MHz (like 3-5%).
Thus my HF probe and the others (except the tek P60** series) only need a single compensation screw.
The tek P6015 has 900 pots and trimmers right? turn this one a weee bit this way, the next a weee bit the other way.... then do it again, and again, and again.
1 2 3 4  last
