  • Guests: 26
05/07 a.gutzeit (63)
05/08 wpk5008 (34)
05/09 Alfons (36)
Does anyone know how these LiDARs work?
1 2 3 4
Fri Aug 12 2011, 04:40AM Print
From my friends at the IARC, who are almost all using this device -> Link2
1313124044 2431 FT0 Lidar
(From the BNM-IT India team power point presentation.)
Im thinking of using the URG-04LX-UG01 simple one (1,200 USD), but the Michigan team was using the 6,500 USD one.
Do these devices use phase relationships to determine distance? or time of flight? If they use time of flight then the minimum useful range is 20mm, in 20mm the speed of light would mean very short emission, detection and a very fast clock.
I really think they use TDOA like the RF foxhunts with the non-moving electrically scanned radio antennas that amatures build.
Bjørn
Fri Aug 12 2011, 05:59AM
A common method is to modulate the laser (often at several frequencies) and record the returning signal. From the different phase shifts at different frequencies you can calculate the distance. The webpages for URG-04LX-UG01 suggests that is what they do.
I have a $100 pocket range finder that has a resolution of 1 mm with a range of 50 m that uses that method.
Fri Aug 12 2011, 01:12PM
Bjørn wrote ...
Oooo... thats just the explanation i needed. Bjorn, which lidar do you have?
We are all having problems with the data rate on the $1200 one being about 12 hertz for the $6,500 they are getting 40 Hertz, i think the electric motor is the slowest part being mechanical, 2400 rpm, so maybe i could mod a pocket one like yours.
Carbon_Rod
Fri Aug 12 2011, 03:40PM
SLAM + URG driver:
You can find the 1cm resolution @ 5m one for under $3500, but note they are a fragile device originally intended for use as factory light curtains.
The Kinect at $100 for both video + LADAR-like scanning is unbeatable in terms of price:
Cheers,
Fri Aug 12 2011, 04:01PM
Carbon_Rod wrote ...
SLAM + URG driver:
So far they've all survived really bad crashes multiple times, when the rest of the machine went to pieces. There are 6 teams using them and they've all crashed but not had a Lidar fail yet.
Cheers,
But so far the Dubai and USC teams have the most experience with the Kinect and they say it cant see or generate useful data past 30 inches or so (for navigation, LiDAR), dont know what you all think, but thats what they said. The Dubai team was going to use both, but wanted to use the kinect only if possible.
PSCG
Fri Aug 12 2011, 06:05PM
PSCG Registered Member #3792 Joined: Sun Mar 27 2011, 06:07PM
If you want more information about Lidars, check Sam's Laser Faq - Laser Insruments and Applications. He has put a lot of work about them (and it seems that isn't difficult to construct something like this ether).
Fri Aug 12 2011, 08:20PM
PSCG wrote ...
TY PSCG, i really need a more optimal solution, so ill look at sams stuff.
Pinky's Brain
Fri Aug 12 2011, 08:31PM
wrote ...
I assume you mean record the interference of the returning light with the (attenuated) original?
If you just record the returning signal you still have the problem of needing to detect minute time of flight for high resolution (~3 ps for 1 mm resolution). The modulation only helps with aliasing.
Fri Aug 12 2011, 10:05PM
Pinky's Brain wrote ...
wrote ...
I think I wil use the one called phase difference or some such name they call it.
Bjørn
Fri Aug 12 2011, 10:24PM
Yes, it is the phase difference that is recorded.
I have one of the Bosch units and it is very accurate but the refreshrate is about 3 Hz so it would be very slow for this use.
