pics of blown Electronics.
Chris Cristini, Sun Nov 23 2008, 03:41AM
i blew a mosfet today on my zvs and it sounded like a 22 bullet three pieces flew off and i got hit with one.
Re: pics of blown Electronics.
Arcstarter, Sun Nov 23 2008, 06:21AM
Well, i do not have pictures because i usually do not blow my stuff up. But i have killed over 40 irfp460 mosfets, probably 10 or 20 other random mosfets, I purposely blew a microwave diode up by shorting it across a 12 volt battery, broken many flyback cores, fried 2 or 3 mots, blown up a few capacitors, over 50 ne555's(more like 100's), and just today i blew up two regulated power supplies. There has been much more stuff i have fried, but i cannot think as it is like 1am right now :).
Weston, Sun Nov 23 2008, 06:49AM
I have my fingerprint in the metal backing of a mosfet driver
. I will see if I can find that to take a pic.
Dr. Dark Current, Sun Nov 23 2008, 08:46AM
mmm..... CRATERS!
Myke, Sun Nov 23 2008, 09:50AM
I don't have any pics of the things I have killed because none of the failures were all that amazing. I have killed 2 IRFP250Ns in my ZVS flyback driver. 3-4 555s in my old iggy coil driver (that's when I decided I needed to get a better driver). One MOC because I was overrating the voltage with it resonating with 2 MOTs (connected so it only outputted 2kV). And one random MOSFET the first time I made the ZVS flyback driver (Vds rating was only 60V...)
Hazmatt_(The Underdog), Sun Nov 23 2008, 03:50PM
heheh Overclocking gone terribly wrong...hehehe
ConKbot of Doom, Sun Nov 23 2008, 04:47PM
Dr. Kilovolt wrote ...
mmm..... CRATERS!
"I dont think the issue is a weak 5v bus"
rp181, Sun Nov 23 2008, 04:58PM
Imagine 2kJ through a potted LED (the LED was potted in green epoxy).
Chris Cristini, Sun Nov 23 2008, 08:49PM
mmm..... CRATERS!
wow what happened there.
Dr. Dark Current, Sun Nov 23 2008, 09:02PM
crazy4 wrote ...
A bit of an overcurrent and overvoltage? Lets say, 2 kilovolts at 6 amps?
coillah, Sun Nov 23 2008, 09:36PM
Dr. K, I have never seen anything like that! That's nuts!
LithiumLord, Mon Nov 24 2008, 02:09AM
Gah, bad I made no picture of the fun I had in the lab. I had to test an old Soviet AFC analizer (yeah-yeah, in Soviet Russia, the caps blow you :D). Of course I hit the switch with my very common and favorite "And now it's gonna go crraaack!" quote (came from the term of a thyristor invertor shoot-through lockup, which here is translated almost the same as "crack-through", so apparently we invented a term of "crack-out", which, of course, is a result of a transistor invertor shoot-through when they crack sending parts of the casing flying around). "Nah, why?" - my co-worker replied. The tube lighted up, I could see traces and things just felt even not to go wrong, excepting the trace slowly moving down (old capacitor leakage as I guess now) and some weird smell I thought to be dust etc (that device came from 60th iirc). After my second "How to get the goddamn trace back?!" question (the machine ignored my attempts to do it with the resistor handles) however the answer came loud and (un)clear - the blast was so loud it even rang in my ears for a while (couldn't scare me as I'm always ready for alike things). A bright shotgun-style flash, weird dense smoke with an even a bit enjoyable smell, a wasted fuse - and it's time to watch the aftermath. Was a sight to see - the floor had an oil mark of a few squares (the pattern of the ventilation grate it all was shot out through), and inside the box the huge el capacitor hull stood like a shotgun shell, with all the fill scattered all around. The biggest cap blow I ever seen!
CompWiz, Mon Nov 24 2008, 05:09AM
I think this image is posted somewhere else too.
Induction heating with ZVS flyback driver...
Also, a bug crawled into one my ATX computer power supplies, BZZZT! Followed by smoke coming out of the vent...
Steve Conner, Tue Nov 25 2008, 10:41AM
Here's one I asploded earlier
aonomus, Tue Nov 25 2008, 04:37PM
When I was making my boost converter, I suppose the 1M dropping resistor failed, sending 400V into the comparator, which failed short, and sent 400V straight into this 555...
Avi, Tue Nov 25 2008, 05:12PM
I had a 555 go like that, when i looked at it under a microscope i found on the circuit inside some microscopic text TIxx (xx being 2 numbers i guess it was a year, i don't remember the numbers now)
Robert2, Tue Nov 25 2008, 07:31PM
Some IRFP460... I must started buying a IGBTs...
Linas, Tue Nov 25 2008, 08:06PM
jovica, Tue Nov 25 2008, 08:55PM
Steve McConner wrote ...
Was this the half bridge from your DWSSTC?
Just wondering because the GDT looks very similar to the one used here
uzzors2k, Tue Nov 25 2008, 11:02PM
Obeying incompetent sign writers isn't easy.I popped a timer with my boost converter once too, accidentally had my multimeter set to current when I decided to measure the bank voltage.
rp181, Wed Nov 26 2008, 03:43AM
Wow, i blew a couple on a boost converter too. It went in a shower of sparks and shooting a epoxy chunk at my finger =p
Mattski, Wed Nov 26 2008, 06:21AM
The microwave mortuary. A nice collection of mishaps from microwaves101.com.
Mads Barnkob, Wed Nov 26 2008, 09:46PM
crazy4 wrote ...
FOOOOOOOCUUUUUUUS!!!!
Chris Cristini, Wed Nov 26 2008, 10:31PM
ha ha sorry i don't know how to use that camera.
rp181, Thu Nov 27 2008, 02:04AM
~900J through IGBT. After, more than half of bank energy was left.
Neil, Fri Nov 28 2008, 08:32AM
This is a capacitor I blew up, and the resulting damage to the case I had enlosing it. At the time it blew up, voltage was 4000V with the bank having a storage of 360uF, 2880 Joules.
aonomus, Fri Nov 28 2008, 08:53AM
Did you ever solve your capacitor problem or was your project a big bust Neil?
Neil, Fri Nov 28 2008, 09:46AM
aonomus wrote ...
I decided to not risk wrecking the rest of the case from another cap exploding, I was lucky it was only the end piece of plastic, a few hrs and some plastic and it should fix up fine. Instead, I ordered the real deal from general atomics energy products (once maxwel I believe). A big pulse cap, 11kv at 525 uF, 125,000 amp rating. It just came into Australia this week after patiently waiting for the last 14 or so weeks for it to be made, should have it on my doorstep in this comming week. 100 kg of capacitor, very excited
Tom540, Fri Nov 28 2008, 10:23AM
Neil wrote ...
aonomus wrote ...
Just curious, How much was it? General Atomics is right next door from where I work. I was thinking of getting a few things from them but everything looks so expensive so I never got any quotes.
Neil, Fri Nov 28 2008, 11:19AM
Tom540 wrote ...
Neil wrote ...
aonomus wrote ...
It was $9,913 USD which was about $12,000 AUD for me with the exchange rate at the time. If you buy 4 or more, this price just about halves. Unfortunately for me, it was another $3,800 AUD to import it and pay frieght, tax etc on it so I just bought one. They seem very easy to deal with and I had no problems importing it for anyone else considering something like that.
Kizmo, Fri Nov 28 2008, 07:17PM
ZVS Explosion :)
sounded like .22 shot and pieces of mosfet casing were flying around my room
Chris Cristini, Fri Nov 28 2008, 09:55PM
nice u know how i feel.
Turkey9, Sat Nov 29 2008, 06:05AM
I was playing with a half bridge and thought that a couple 35v tantalums would probably work with a 33v non regulated supply..... small sizzling sound accompanied by a small plume of smoke.... turned off power, didn't find anything obviously wrong, and decided to fire it back up!!! sizzling sound again, and then a stream of sparks and fire shot by my face (which was about 4 inches from the caps....)!!!! hehehe wish i could've got a picture of that!
aonomus, Sat Nov 29 2008, 07:21AM
Tantalums are like miniature hand grenades. They don't like overvoltage or reverse bias, infact, they hate it.
Tom540, Sat Nov 29 2008, 07:29PM
Neil wrote ...
Tom540 wrote ...
Neil wrote ...
aonomus wrote ...
9,913 holy shit! I knew they were expensive. Was that one of their standard caps or custom?
jovica, Sat Nov 29 2008, 09:25PM
Tom540 wrote ...
I think they were custom made as he says.
' It just came into Australia this week after patiently waiting for the last 14 or so weeks for it to be made. '
Im not sure but if they were standard caps i dont think you would need to wait for them to be manufactured.
rp181, Sat Nov 29 2008, 09:44PM
nope, not custom, part number 33943.
These are big expensive products, it makes no sense to have them in stock. How many people but these? when these are usually bought, its larger quantity (like the navy's rail gun, they used capacitors from this company). Stock would just age them.
Chris Cristini, Wed Dec 03 2008, 05:38PM
11kv at 525 uF, 125,000 amp rating. That's a huge cap certain death wow.
rp181, Wed Dec 03 2008, 09:42PM
not certain death, just hope it blasts your arm off first =/
Neil, Thu Dec 04 2008, 10:15AM
rp181 wrote ...
I guess just hoping for a finger would be wishful thinking...
Sorry Tom540, I missed your question as I havn't checked back for a few days. As rp181 correctly pointed out it is indeed part number 33943 and they dont stock them.
Dr. Dark Current, Thu Dec 04 2008, 12:50PM
Neil wrote ...
rp181 wrote ...
May I ask, what is the intended usage for the capacitor? I'm pretty sure it's not just for exploding stuff or crushing cans
LithiumLord, Fri Dec 05 2008, 12:25AM
Was messing around an old SF generator in the lab recently. I have no idea what happened (my guess is that someone... well, I even know who actually as he was arguing with me on that topic - well, he put the three fuses in the fusebox where only one was meant to be in place - the machine is really old, so they made a three-socket fusebox where you have to set the fuse in the proper socket in order to choose between 110, 120 and 220vac mains feed), so there was something shorting out the high voltage coming from anode feed circuit, maybe a cap failed or some tube got wasted. The picture below is the double kenotrone I placed instead of the one that was placed on the output - it's filament was damaged and I thought it was a result of a mechanical shock. How wrong I was - a few seconds after I let my eye away from the new one it instantly heated up to glow and it's filament blew off before I could switch it all off. So (yes, we have a virtually unlimited storage of those) I set up the third one just to make this pic and instantly cut the power before anything goes any worse - it was a success
ps also we have a virtually infinite number of ruined mobos on the scrapyeard, so I'll try out a tiny 12v CWDRSSTC on the fets from them - non-decoupled H-bridge with tantalum bypass, the signal will be fed from a CT through a schmitt gate to four UCCs with delay circuits rigged to enable pins in order to inject some deadtime - hope those things have P-FETs as well, or I'll have to use a GDT anyway.
Chris Cristini, Sat Dec 13 2008, 06:47AM
My mot after some serious abuse the camera stinks but all the wire coating is melted together it is like a solid piece now
Dr. Dark Current, Sat Dec 13 2008, 08:36AM
dont use PVC insulated wire for transformer winding
rp181, Sat Dec 13 2008, 04:27PM
burning PVC is toxic.
Anon01, Sun Dec 14 2008, 06:35PM
Putting 2.2kW through a halfbridge of these (44n50, doesn't show it in pic) at 140khz CW mode. Exploded and caught on fire. The back side of the drain pin's supportive plastic is blown away, though the angle from this picture doesn't show you the other side of the pin. Surprised me.
Mads Barnkob, Sun Dec 14 2008, 08:48PM
rp181 wrote ...
All we do is toxic, its just a matter of exposure time and dose :)
Chris Cristini, Sun Dec 14 2008, 09:08PM
MadsKaizer wrote ...
rp181 wrote ...
Yes I agree
Steve Conner, Sun Dec 14 2008, 10:23PM
Paracelsus agreed too:
We'll now take a break from switched-mode carnage, with some bad components from an old Grundig table radio I'm restoring. This was so soon after WW2 that the Germans were still making capacitors out of ear wax.
Anon01, Mon Dec 15 2008, 07:25AM
And some more, fresh today. I need to figure out what is going on.
Backyard Skunkworks, Fri Jan 23 2009, 10:35PM
Blown flash cap. Reposted since the old one was lost due to the skiddie crackers.
Kizmo, Tue Mar 10 2009, 11:15AM
48V 1.9kW Powersupply blew
Notice melted mostef clamp
GeordieBoy, Tue Mar 10 2009, 02:22PM
what did you do that made it explode so violently!?
Chris Cristini, Sun Feb 28 2010, 04:15PM
Kizmo wrote ...
Kizmo What happened there looks toasty.
radiotech, Sun Feb 28 2010, 04:50PM
In the trade, if you were close enough to something that failed, you probably caused it. If anyone knew you were close, you will get the blame anyway.
Dalus, Sat Apr 03 2010, 02:48PM
Humz I just blew a ferrite core in my boost converter don't know how it happened yet but I was surprised to find the core scattered over my desk in fragment. Too bad there isn't much to see just a shattered core.
Conundrum, Sat Apr 03 2010, 06:16PM
Bad caps = KABOOM! (note- this monitor was made in 2005, at the height of the bad caps fiasco)
Things haven't improved much it seems.
-A
lpfthings, Sun Apr 04 2010, 04:55AM
240V mains shorted thru a LED ...
It's interesting how it split where the bonding wire was.
Nicko, Sun Apr 04 2010, 07:02AM
Conundrum wrote ...
FWIW, I have a Samsung R74-series 40" LCD TV that has an identical standard failure mode in its SMPS - I just re-capped it with decent Panasonic caps and its fine now (lots of forums discussed this).
The annoying thing is that Samsung are generally regarded as a very good quality make, and even they had problems with this (my TV dates from early 2006, so probably made in late 2005).
Hon1nbo, Sun Apr 04 2010, 04:01PM
lpfthings wrote ...
I once forgot the resistor on a Tricolor LED from radioshack, and pumped 9-12V through it - I swear I never knew that LED Shrapnel could fly across a room in multiple directions
-Jimmy
lpfthings, Mon Apr 05 2010, 01:00AM
That LED was probably spared of a vaporization because it was in a bezel when it exploded
Chris Cristini, Mon Apr 05 2010, 01:31PM
Oh my
some times I wonder.
Andrew L., Mon Apr 05 2010, 02:59PM
I think that the first video is fake.
Linas, Fri Apr 16 2010, 04:19PM
hrrr
some one removed ground during test full power, so i get fail in driver because of extremely large potential differences and i killed one brick
klugesmith, Fri Apr 23 2010, 09:33PM
From long ago in this thread:
Looks like an inherently poor design, also known as a learning experience.
Power resistors normally get very hot, and are made of stuff that can tolerate it.
This style can exceed 100 degrees C at rated power, even with free air circulation (which is blocked by the capacitors).
Plastic film capacitors don't like it hot.
[edit] Also, the smaller R's should be derated or have more room between them. Resistors get just as hot as anything else of the same size, in the same place, dissipating the same power.
Steve Conner, Sat Apr 24 2010, 08:40AM
I noticed that Karol got these pics published in Microwaves101's Microwave Mortuary.
(scroll down a bit)
He supplied some information and admits that the resistors were a "design fail".
My personal favourite is the cratered Xilinx FPGA. I'm working with them just now and feel like doing that most days.
Nicko, Tue Apr 27 2010, 07:46PM
One of the reasons why my old Perreaux needed TLC:
I find noisy laptop drives really, REALLY, annoying:
lpfthings, Sun Jul 18 2010, 09:42AM
Made my first crater today :(
Thats what happens to a triac when you try switch a 1.2kW AC compressor without waiting for the pressure to stabilize ...
HazzWold 1993, Mon Jul 19 2010, 01:21AM
Fried resistors and blown transistor.
lpfthings, Thu Aug 26 2010, 04:12AM
Had a little RGB DMX controlled LED par, it stopped working one day, Fuses was still fine, but opening it up to find this:
I haven't been able to find a replacement, anyone know where to get one? It's a THX201.
Plasmana, Thu Aug 26 2010, 12:04PM
I have killed loads of semiconductors already, but rarely have them to fail dramatically
Heres two mosfet that exploded, and the one with an resistor on it made a heck (and I mean alot!) of smoke!
Sometimes my semiconductors gets mixed up with others - I picked out "assuming it was a mosfet and didn't bother reading the part no." from the bag of mosfets. I then connected to the drive circuitry and BAM! It turns out to be a voltage regulator...
A while ago, I was hoping to blow up a flash tube with my large cap bank for fun, but something a little more interesting happened...
Dr. Slack, Thu Aug 26 2010, 01:23PM
Looks like you managed to turn a light-emitting diode into a pair of dark-emitting monodes
Muttyfutty!, Thu Sept 02 2010, 09:43AM
dark-emitting
Wow, I love the soud of that;
"It emits darkness on the whole world Muhahahahah!!! *evil laugh*"
radiotech, Thu Sept 02 2010, 09:53PM
Wonderfull, we now know the half-light of green LED's is 240 volts.
radiotech, Mon Sept 06 2010, 06:22PM
Meters have fuses and the fuses have voltage ratings and the best meters have fuses with interrupting capacity in kiloamps on the fuse.
But the reason for these fuses and the ratings on the meters is to guarantee they wont explode if used within the rated maximum voltage .
High voltage, especially high frequency high voltage is rated with a frequency/voltage derating curve.
But all this aside, spark voltages dont care about fuses.
If you arc-over a meter whether or not it will explode into bits, in you face depends on how much energy the circuit can furnish.
I have toasted my share of expensive instruments, happily most were not mine own property. I am also aware of a Scopemeter that died whilst measuring the trend on a big SCR drive, however I was not close enough to be blamed.
Killa-X, Fri Sept 17 2010, 01:18AM
Does a blown trace count?
I used an etched board for my 30 flash capacitor bank. This was near the positive connection, to my ring launcher. I charged it to 200V, after the 5th time, i heard a poof. Then I charged to 200V again, the SCR wouldnt fire. Discharged with a power resistor, and came to find my trace exploded! This is the reason I'm going to thick aluminum busbars!
HazzWold 1993, Sun Sept 19 2010, 01:26AM
Circuits
Killa-X, Mon Sept 20 2010, 03:01AM
What happens when you put 300V @ 200J into a 16V capacitor...
dmg, Thu Oct 14 2010, 12:53PM
Never send a To-247 IGBT to do a brick's job. EVER!
dmg, Thu Oct 14 2010, 12:55PM
gah, didnt upload, lets try again
Kizmo, Sun Apr 24 2011, 08:38PM
I have extreme failure i want to share with you guys :)
And video is more than 1000 words so:
No one was hurt because i knew very well something like this can happen so we had necessary safety precautions. Cleaning of floor and ceiling took over 3 hours.
Why did it happen? - I dont know. Maybe something arced over or capacitor string had runaway failure. Lesson learned hard way.
magnet18, Sun Apr 24 2011, 08:49PM
Dang, if you had been standing next to that we might have one less member O.O
Why'd you clean the ceiling? I think it looked impressive
Kizmo, Mon Apr 25 2011, 08:12AM
Actually i was roughly 1 meter away from the doubler when it blew up. Between me and the doubler was 25mm thick MDF plate and i was wearing full face shield and hearing protection.
New pair of underwear was needed
James, Mon Apr 25 2011, 05:03PM
Nicko wrote ...
Conundrum wrote ...
The bad capacitor fiasco was great, I got a good pile of free equipment out of that, it was all nice and easy to fix. :)
I didn't take pictures of the damage, but I've had a number of mosfets explode. I had a half bridge running when I turned the juice up too high and BANG, bits of plastic shrapnel whizzed by my face. I place a shield of some sort over such things now when in the testing phase.
I recently stuck a lytic in backwards by accident and didn't notice until it vented a jet of awful smelling smoke right in my face while I was hunched over it with a scope probe. Thankfully it didn't blow the can off, I've seen that happen before.
magnet18, Tue Apr 26 2011, 01:41AM
Kizmo wrote ...
Did the brick tear a hole in them?
Kizmo, Sat Jun 16 2012, 01:57PM
Me and capacitor banks just dont mix
I knew this was going to happen sooner or later so my bank is put together in a way that lets failing capacitor to fly out without damaging anything else.
Terminal piece and can were left attached to busbars while bottom end and actual capacitor element flew across the room :p
Alex M, Sat Jun 16 2012, 08:09PM
Very thin secondary wire, too thin to handle without it snapping. Its more like tape with thin magnet wire moulded into it.
Jrz126, Sun Jun 17 2012, 11:28PM
Large IGBT brick ran with low cooling.
Ben Solon, Wed Jun 20 2012, 01:39AM
playing with a self oscillating resonant smps on a breadboard:
first i got the feedback winding phased wrong, and i decided to let it burn for a while. the white ash/plastic stuff goes all the way to the die.
after i was getting 24v dropped across my 10 ohm dummy load, i just put a led in its place to test current flow. red flash... bang! the missing side was facing me(ouch). knowing now that it worked, i swapped the open circuit resistor for a good one, and it was able to smoke 1W's in seconds
Tetris, Thu Jun 21 2012, 03:36AM
I have destroyed a few 555s before, but none of them had too spectacular an asplosion or destruction. I did, this once, find a tiny Pikachu toy that I have no idea what it did, because for a long time, it sat in my room, not working. (it was a plastic one, not one of those adorable fluffy ones that talk) I had no idea the polarity of the thing, so I guessed, and I guessed wrong. I then learned what pikachu would smell like if his thunderbolt went the wrong way. I kept the toy, but it smelled of magic smoke for a really long time. I have no idea where i kept the circuitry of it.
brandon3055, Thu Jun 21 2012, 05:09AM
aonomus wrote ...
Haha I had exactly the same thing happen to me when I was prototyping mine the dam thing jumped right off the breadboard and tryed to kill me LOL
2Spoons, Thu Jun 21 2012, 06:31AM
Used to work in electric fencing - wish I had pics of some of the lightening damaged ones! Generally no copper left on the pcb, and lots of loose burnt things lying around in the case.
brandon3055, Fri Jun 22 2012, 07:40AM
Everyone tells me you can't fix a blown bolb but that work fine if you give them a little more power LOL
]imag0569.jpg[/file]
]imag0567.jpg[/file]
Chris Cristini, Thu Dec 27 2012, 04:05AM
Some nasty Blow outs HAHA.
I forgot this Thread.
Kizmo, Thu Dec 27 2012, 10:09AM
SKM150GB-128D
Oops..
PSCG, Thu Dec 27 2012, 12:04PM
Got a microwave oven from the electronics recycling. Externally was in good condition and no electronic component inside had any visible damage. Until i decided to get the magnetron tube out:
Kizmo, Sat Dec 29 2012, 10:28AM
Sigh..
Still unclear what happened. I wasn't even pushing the damn thing and one transistor let go.
Polonium210, Sun Dec 30 2012, 09:49PM
Does this count?
Chris Cristini, Mon Dec 31 2012, 05:38PM
Oh my ZVS Driver? good one.
Polonium210, Mon Dec 31 2012, 06:03PM
Chris Cristini wrote ...
No, it was a half bridge of 60n100 IGBT'S for my SSTC. I was trying an experiment with an arduino controlling a laser from across the room aimed at the fiber input on my driver. Was running an audio mod to the coil but when the arduino reset the laser went on 100% duty killing my bridge!!
Conundrum, Tue Jan 01 2013, 09:30AM
oops...
Does a battery count as a component? I have a lithium cell here which ruptured spectacularly in storage, split the casing as well.
The two cells in parallel with it were history as it decided to short out.. grr.
Chris Cristini, Tue Jan 01 2013, 04:10PM
