Need help with coilgun barrel
ritaismyconscience, Sat Nov 10 2018, 05:38AM
Hi,
I got 6 16000uF 350V capacitors for a very low price on Ebay. I finished the charging circuit (ZVS), and it works. How should I create the barrel and how many turns should I use?
Sulaiman, Sat Nov 10 2018, 10:40AM
You can start here
Re: Need help with coilgun barrel
V2006, Sat Nov 10 2018, 11:55AM
To wind a coil, you will need a copper wire with a cross section of more than 10-12 mm 2 (for example, 3x4 mm), but you can wind a round wire with a diameter of 2.5-2.6 mm if two wires
