I am still trying to build good power supplies for plasma globes and have a question about voltage specifications.
I recently bought two old color TV flybacks for a CTC20 RCA TV. Part number FLY 352. After some searching I found
a schematic for the TV that shows the rectified voltage is 25kV.
Does this mean that I can use the flyback at a 26kV Pk-Pk AC voltage? I will be grounding the low side of the secondary
when I use it.
Thanks for any answers. Extra thanks for right answers...
Cheers.
TV Flyback Voltage
klugesmith, Sat May 13 2017, 02:08PM
When Alan says old color TV, he means really old color TV. Here is a video of someone fixing a flyback in similar (CTC28) set.
The secondary winding termination is in the form of a tube anode cap, for the EHT rectifier.
Good luck with those, Alan. Please let us know what you learn about the transformer parameters. I presume it has a gapped ferrite or iron powder core. From the normal flyback application, we can get a secondary volt-seconds number that's comfortably away from saturation. Thus a kV per kHz limit for sinusoidal voltage. Probably about the same as other color TV flybacks not used with voltage multipliers.
TV Flyback Voltage
klugesmith, Tue May 16 2017, 09:52PM
[edit]Bottom line first! The stresses on your transformer from the reported voltage and frequency are substantially lower than those in its original flyback application. That's without considering the output
current and associated copper losses. [\edit]
Alan, here's one amateur's simplified review and conclusion about sine wave voltage limits. For now we'll ignore the winding's parasitic R and C values, and circuit resonances.
Take an old TV flyback (LOPT) secondary winding that's designed to power a color CRT anode, via one vacuum rectifier. Let's name some variables:
- Vfly, the nominal output voltage, 25 kV.
- T, the television horizontal scan period. 63 us in NTSC standard.
- Tf, the flyback pulse width. Say it's exactly T/9; that's 7 microseconds.
- Ts, the width of the rest of the cycle. 8T/9, or 56 microseconds.
- Fmax, the design value of magnetic core flux at highest point in cycle.
We don't need to know the values of Fmax or Ns, the number of turns in winding.
The induced EMF in secondary winding is, at every instant, proportional to dF/dt -- the rate that magnetic core flux is changing. (As discovered by Michael Faraday and Joseph Henry almost 200 years ago.) The ratio is fixed by design; in fact it's just the number of turns. The ratio doesn't change when we apply different frequencies and waveshapes to the same transformer.
In original application, the flux ramps from zero to Fmax during Ts, then back to zero during Tf. Slope dF/dt is -9 Fmax/T for the fast phase, which induces +Vfly. (The slope is 9/8 Fmax/T for the slow phase, which makes the winding voltage -Vfly/8.)
Consider a symmetrical square-wave voltage with the same old period, T. The flux can swing both ways (+/- Fmax) if the device is used as a regular transformer. Ramp from -Fmax to +Fmax for a half cycle, then ramps back to -Fmax in the other half cycle. Both slopes have magnitude dF/dt = 4 Fmax/T. So the voltage magnitude, both pos and neg, is 4/9 Vfly. About 44% of 25 kV, so 11.1 kV.
How about sinusoidal voltages and fluxes, with the same Fmax and T values? dF/dt reaches its extreme values at flux zero-crossing times. Peak dF/dt is 2 pi Fmax/T. So the voltage amplitude (peak value) is 2 pi / 9 Vfly. About 70% of 25 kV, so 17.5 kV.
RMS voltage is sqrt(2) pi / 9 Vfly. About 49% of Vfly, so 12.3 kV.
I'm not sure if peak-to-peak voltage of a sine wave is particularly relevant, except for being easy to measure on an oscilloscope screen. Its value, for the same frequency and flux level as original flyback circuit, is 4 pi / 9 Vfly. A ratio of 1.4, yielding 35 kV pk-pk.
All three examples have the same Fmax value, shown (by original design) to be reachable without saturating the core material. Core loss power, and temperature rise, might be as much as 4 times higher in the bipolar cases.
Without changing Fmax, all voltages can be increased in direct proportion to frequency. Not counting limitations due to insulation or core heating.
I hope that helps you feel more at home with your transformers, Alan. And that it's not seriously flawed.
-Rich
p.s. Here are a few SWAGs at actual values, which we didn't need for the comparison above.
Original application flyback pulse has a voltage-time product of 0.175 volt-seconds.
If Bmax (peak flux density) is 2760 gausses, in a 0.5 inch round ferrite bar, then Fmax = 35 microwebers. Fast slope dF/dt is 5.0 Wb/s, inducing 5.0 volts per turn. 5000 turns for 25 kV. Total flux linkage (max) is 0.175 weber-turns.
