'Water Battery': Charging water by means of a mini water bridge
Proud Mary, Mon Dec 05 2016, 11:46PM
'Water Battery': Charging water by means of a mini water bridgeThis is one of those experiments where one can get in on the ground floor using simple equipment which I, and others here, already have.
Whether ordinary commercial de-ionised water will be pure enough to make it work we will have to see!
There's no knowing where one might go starting off with an experiment like this!
Re: 'Water Battery': Charging water by means of a mini water bridge
kimbomba, Tue Dec 06 2016, 01:45AM
It works with commercial de-ionized water. I did it sometime ago, it worked on the first try.
