DRSSTC with CM150DY-24NF, Freqency?
LarsE, Fri May 13 2016, 09:44PM
Several years ago i did build a few induction heaters, SSTC's and a DRSSTC, but after moving i haven't done much in the field of power electronics.
Now iam thinking of starting a new DRSSTC build, i recently bought a UD2.7C board from loneoceans and happen stumble upon few NOS CM150DY-24NF and CM100DY-24NF bricks for just 15USD each.
DatasheetMy idea was to build a reliable medium sized DRSSTC powered from either 1-phase 10A 230v or 3-phase 16A 400v outlet.
The question is what frequency they can manage?
I would think 70-80kHz would work without any problems, but have anyone used them at higher frequencies like 100-150kHz?
loneoceans, Sat May 14 2016, 12:44AM
LarsE wrote ...
Yes they'll work fine.
LarsE, Sun May 22 2016, 02:09PM
That sounds good!
I believed i had 200pcs of Panasonic ECW 2500v 0.043uF caps for the MMC in my "junkbox", but when i found them they turned out to be just 0.0043uF.
I will probably just get some CDE 942C caps instead.
Re: DRSSTC with CM150DY-24NF, Freqency?
Alex Yuan, Thu May 26 2016, 12:52AM
I've used CM200's up to 100kHz, I think CM100s should be fine past 150kHz even
Mads Barnkob, Thu May 26 2016, 05:38AM
If you want to be sure, you could do the math and datasheet extrapolation to find out:
