Verschrottix' DRSSTC
Verschrottix, Sun Apr 17 2016, 02:35PM
Hi guys after i finished my ARSGTC (i'll make a new thread about this coil) i want to built a rather "big" DRSSTC. I'm sorry i will use for this thread the metric system because i'm german. So back to topic the coil should be abou 2m tall with a flat primary and a sceondary with 250mm in diameter and 1000mm lenth. The Topload will be a "skelleton"-Topload (250mm thick and 900mm in diameter).
Here some datas:
-Fullbridge with SKM600GB-126D-Bricks
-12mF 400V Buscaps (first rectified max. 270VAC from my varaic )
-UD2.7 as driver
-about 40kHz fres
-about 500nF primary capacitance
-2 seperate GDTs (one for each halfbridge)
-about 1kA primarycurrent
Here is a picture of my bridge (not finished). The other stuff is not built yet.
