synchronous spark gap
Bud, Mon Aug 31 2015, 11:42AM
Hi All, Can anyone comment on RSPG's. I have a washing machine motor that has been converted to be synchronous @ 1550~ rpm.......checked it with a strobe light and it is steady. The question is this? Is there an advantage of electrically controlling timing the motor to get in phase vs mechanically rotating the motor to get in time? I would think that once mechanically set the motor will always be in phase and the contacts would always be in the correct alignment. Yes No What?
Any help would be appreciated.
Bud
klugesmith, Mon Aug 31 2015, 07:50PM
Hi Bud. Nice TC you got there. Could you clarify
"synchronous @ 1550~ rpm.......checked it with a strobe light and it is steady." Sounds like the RPM value on motor nameplate, which would be the speed under load before modification. It would be the synchronous speed when power frequency is about 51.7 Hz.
Please tell us about your strobe light!
Did you convert the motor by making four well-balanced flat spots on the armature stack? Then its rotation phase should be the same after every start, except for an arbitrary multiple of 90 degrees, plus a shift that depends on load torque. Adjustments made mechanically should be just as stable as those made electrically. I think the mechanical approach (by turning the motor case or the fixed-electrode plate) is just as easy, just as robust, and can just as easily be tweaked while the coil is running. Remotely adjustability would be a nice feature.
This advice is from someone who has never made a Tesla coil. But I have collected, made, and/or played with many kinds of synchronous motor and line-synchronous stroboscopes. My synchronous conversion of a MWO fan motor was successful (with an asterisk).
Re: synchronous spark gap
Signification, Tue Sept 01 2015, 12:26PM
@klugesmith:
Do you know the resistance and wattage of that monster train-brake resistor in the photo? Also the weight?
Bud, Tue Sept 01 2015, 01:00PM
Hi klugesmith, I did machine 4 flats on the rotor according to the specs on the HVTESLA website of 25% of the rotor diameter. It does synchronize very well as much as I can see. For a strobe light I took my sears engine strobe light from many years ago and hooked it up to a 12v battery and held the ignition lead clamp close to my VTTC primary while it was on low power. I know this may sound a little archaic but it was the only way I knew how as it runs on 60 hz.. I recently stumbled upon the plans to modify a radio shack party strobe light which is a much safer way to go. I am not sure of the exact motor RPM but I wanted to clarify it was not 3600` rpm 2 flats but 1500` rpm 4 flats 60 hz........4 contacts. My plans are to build two rotational plates (one for the motor and one for the spark gap frame) that allows me to turn the plate ~45 degrees so that I can line up the electrodes at 60 hz.
Not sure if this washing machine motor will have enough HP to overcome the wind friction of the rotating electrodes but we will soon see. Nothing ventured nothing gained. The motor was free to me.
I will definitely take some video shots and put up a youtube video showing how this all works once complete. I have my own tool and die facility with 22 emloyees. Can engineer and build just about anything.....the big trick is knowing how it works before hand.
Bud
Bud, Tue Sept 01 2015, 03:46PM
Bud
klugesmith, Wed Sept 02 2015, 01:18AM
Hi Bud.
Long time since 60 Hz synchronous stroboscopes have been discussed here.
Here is a link to the one I used for that video. Light source is a nominal 1-watt LED. No xenon or high voltages are involved.
The only integrated circuit is a single 555.
Previously posted to 4hv in 2011. Has it been that long since the 555 contest?
Forgot that it mentions me burning out an AC wallplug transformer
by drawing power through a half-wave rectifier.
@Sig: I forgot the measured resistance of my serpentine cast iron resistor, and never knew the power rating.
The limiting ambient temperature for power derating is probably well over 200 degrees C.
Bud, Wed Sept 02 2015, 02:00PM
Hi siginification, In regards to the train brake I am not sure what you are referring to. the only thing that comes to mind is the monster variac I have. It is 85 amp. Has the big dial on top of a 36" high case 2 ft X 3 ft approx.. I got it several years ago on ebay and I picked it up not far from my home. It came from the Perry nuclear facility east of Cleveland Ohio. A very rare find! Works really nice for this big coil.
Bud
