How to beef up my slayer exciter.
SK1701, Wed Aug 12 2015, 08:53AM
I've built a slayer exciter using a TIP31C running off a 12V power supply. It can light up CFLs around a foot away and creates a half-centimetre arc without a top load. It is based on
this Instructable and the schematic (credit to user -max-) is attached below:
I used a 1K resistor instead of the 10K (10K did not work) along with 2 100nf ceramic caps in parallel. The primary is 3 turns and the secondary is 30AWG wound a 30cm long pipe (several hundred turns. Not sure of the exact number).
I want to increase the power. I have an IRFP250 MOSFET. I also have the UCC37321 and UCC37322 MOSFET driver ICs. Can someone advise me on how I can go about wiring them up to increase the power? If not with these parts, is there any other circuit I could build which would work better.
Thank you.
flannelhead, Wed Aug 12 2015, 10:19AM
You could follow Steve Ward's
Micro SSTC schematic, which makes use of a single MOSFET, a gate drive IC and antenna feedback. It makes for a great first SSTC. You can substitute a UCC37322 for the TC4420, just remember to check the pinouts. He also made
an improved version with an interrupter and a capacitor across the MOSFET tuned for Class E switching to decrease losses. I suppose you could get breakout with one of those circuits even with just 12 volts in. At least it would be way better than the Slayer Exciter circuit.
