Scoping Parallel IGBT's Gate-Emitter Voltage @ 400khz
zzz_julian_zzz, Fri May 08 2015, 04:05AM
Hi Guys,
I'm rebuilding my QCW, but I'm a bit concerned and worried on the G-E driving waveform of IGBTs connected in parallel with different Gate Resistors. I'm driving them with 24v with a driver based on UDs.
I have a video here to share with you guys to know if these waveforms are "OKAY" for driving 400khz QCW bridge. because I don't want to damage any more IGBTs.
As you can see they're not "snappy square waves", but when I disconnect the load (IGBTs) from the GDT secondaries the waveform looks nice, without the curves and with almost no ringing on tops.
I'm welcoming any comments / thoughts for this. Thanks!
Re: Scoping Parallel IGBT's Gate-Emitter Voltage @ 400khz
loneoceans, Fri May 08 2015, 04:54AM
They won't be snappy square waves with the IGBT gates and reverse diodes - in fact the waveform shape looks about right. Is the division 500ns? At first glance the only thing I see is that it seems that the rise and fall times could be a bit better. What transistors are you using now?
You mentioned you previously blew some IGBTs? What IGBTs were they and do you know what they failed?
zzz_julian_zzz, Fri May 08 2015, 05:34AM
loneoceans wrote ...
Hi Loneoceans,
yes the division is 500ns. I am using stgw60h65dfb IGBTs. [these are in the vid]
I am already using thin isolation magnet wire(awg 24) to even reduce Leakage inductance to the minimum so to make rise/fall even snappy, the core I am using is with AL 7000(value taken by doing tests, though I am not sure of its part number / material type).. With the conventional UTP cables, the slope is much more slower/longer that might lead to device heating.
I blew some IGBTs before and I am suspecting that one of the cause is improper(or rather slow) turning on/off of these switches.
Any suggestion to even improve the slopes(rise/fall) of G-E?
also, do you have photos of G-E waveform running at 400 khz? thanks!
