Laser-guided Tesla Coil discharges
dex, Sat Jan 31 2015, 10:05AM
Interesting research on laser guided arc discharges conducted on 350 kV Tesla Coil:
Fig 6 are typical discharge current oscillograms for laser triggered discharges.
Note how strongly damped are these wave shapes. Isn't that unusual?
Secondly, isn't such strong damping in contradiction with antenna signal shown in
Fig.2.(b) (althought peaks are not shown)?
Re: Laser-guided Tesla Coil discharges
Kolas, Sat Jan 31 2015, 05:54PM
long distance projectile-less tazer cannon?
teravolt, Sun Feb 01 2015, 05:30AM
what type of laser is it and could a semiconductor laser be used?
..., Sun Feb 01 2015, 06:18AM
They used
delivering 0.3J in a little under a picosecond, which is about a terawatt of peak power, not quite within hobby reach sadly.
It is interesting to see their results, although I really wonder what the people running the laser thought about having a tesla coil next to their multi-million dollar laser and associated electronics.
Uspring, Sun Feb 01 2015, 04:55PM
Damping depends on the arc resistance, here in the kohm region and the arc inductance together with the inductances in the grounding wiring. In our case we have a tank made from the tesla top load, the inductances mentioned and the arc resistance. From the oscillating freq, about 10MHz from Fig. 6 and the top load of 30pF, the inductance is about 10uH. Q is 2*pi*f*L/Rarc, or about 0.5 for an Rarc of 1k. So the tank is indeed strongly damped.
Secondly, isn't such strong damping in contradiction with antenna signal shown in Fig.2.(b) (althought peaks are not shown)?
I guess the oscillations in Fig. 2 arise from a tank like behaviour of the antenna plate together with the cable to the scope. The oscillations don't seem to have anything to do with the arc itself, since they also appear, when the laser fires.
I found most interesting the short times necessary between laser firing and voltage maxima, i.e. on the order of us's. It is well known, that at burst rates at e.g. a 100Hz, arcs will almost follow previous arcs, even though the arc to arc time is then 10ms instead of us.
dex, Sun Feb 01 2015, 05:53PM
Uspring wrote ...
But normal arc discharges to good grounding aren't so damped. That's the point. Usually, it's 5-10 cycles before arc dyes out...
Uspring, Sun Feb 01 2015, 07:27PM
Is that for tesla coil arcs or DC arcs, e.g. from a marx? TC arcs are long for their voltage, which implies higher arc resistances and thus stronger damping.
dex, Sun Feb 01 2015, 09:42PM
No, I was referring to flying pigs and the linked article is about sparrows. Classical Tesla Coil grounded arcs foot or two long .
If you measure discharge currents, you'll probably see they oscillate much more.
Uspring, Mon Feb 02 2015, 10:47AM
Might be so. In my calculation I found the inductance needed for a 10 MHz oscillation (10uH) to be rather high. It can't be explained by a single piece of short (maybe 1m) of wire, so it is caused either by long ground wiring or some effect in the arc. Lower damping requires even higher inductances, which would also imply lower oscillation frequencies. I don't have any data about this, but I think it is possible that particularly long ground loops might have the required higher inductances with corresponding lower damping.
