New Coil
Graham Armitage, Thu Jan 22 2015, 01:48PM
Well, thanks to the help from folks on this forum the new coil is operational. Thought I would share some specs and pics
Secondary: 4.5" x 20.5", 32 AWG wire.
Topload - 4" x 17" duct toroid
Primary: 9 turns of 1/4" copper tube tapped at 6.5 turns
Tank Capacitor: 3x6 CDE 2kv caps - 303nF
Inverter: CM300DY-24H half bridge with RIFA 3400uF/420VDC power cap
Bus voltage: 340DC - 120AC doubled with 2 sprague 2000uF/200VDC caps
Resonant Freq: 86kHz
Controller: Eric Goodchilds UD2.5b
Max Spark length: 52"
Still doing some tweaks and modifications but overall working pretty well and staying nice and cool. Time to start building her twin
Re: New Coil
bomber315, Thu Jan 22 2015, 03:29PM
this looks very nice! i will be watching this one, i want 52" sparks from 340v bus voltage! :)
New Coil
loneoceans, Thu Jan 22 2015, 06:38PM
Graham Armitage wrote ...
It will be difficult to change the architecture now - not much room for more caps. I am using an H-bridge. Changing bus voltage is tough as all components are rated for the 340v.
It was a half bridge indeed not a H-bridge that you mentioned in the tuning for maximum power thread (unless you're building several coils?). With a half bridge, running at higher bus voltage will give you significantly better performance with your previous MMC (e.g. usually output from a variac will go up to 140VAC giving you ~400V on the bus). Also you could have combined all the threads you created for this coil into one project thread instead. Good job getting it working.
