Internals of a Tek P6013A HV O-scope probe.
Patrick, Wed Feb 02 2011, 05:29AM
ok i start with pics.
The total device (As bougt from Ebay).
Radio Shack UHF to BNC changer.
Re: Internals of a Tek P6013A HV O-scope probe.
Steve Maurer, Fri Feb 04 2011, 04:25PM
Thank you for sharing these pictures with us.
I find the leaf capacitor arrangement interesting.
- Steve
Pinky's Brain, Fri Feb 04 2011, 04:45PM
I assume it's there to couple the high frequency components to the output? Because without it the grounded shield pulls the output signal to ground?
Patrick, Fri Feb 04 2011, 06:08PM
Pinky's Brain wrote ...
This statement eludes me, please clarify.
Pinky's Brain, Sat Feb 05 2011, 12:58AM
Well the grounded shielding has a large parasitic capacitance to the resistor, if that was all there was to the probe then for higher frequencies most of the signal gets coupled to the shielding long before it gets to the low voltage arm of the divider (the electric field along the resistor is no longer symmetrical like it is for instance with your resistor from the other threads with the hoops). I assume the leaf capacitor is not grounded, but connects to the low voltage arm ... so I assume it's there to couple the high frequency components to the low voltage arm to counteract the effect from the shielding ...
Patrick, Sat Feb 05 2011, 04:44AM
Do you mean the 1k (R111) hold up resistor...at HF the 1k (Common Cartbon Comp, 1/2 W) can get much hotter then the HV resistor! charging 3pf and discharging at 75Mhz and 200v must make a lot of heat.
the coax cable, the length from the probe can end, torwards the comp-box spans 10Ft and the center strand has 225K resistrence. therefore 225K/10ft = 22.5kohms per foot.
Pinky's Brain, Sat Feb 05 2011, 02:49PM
Patrick wrote ...
With low voltage arm? I mean the 1K resistor and everything to the right of it in the schematic.
To me it seems that a handheld probe is significantly harder to design than a standalone probe connected through a low induction copper strap. With a stand alone probe you can keep the electric field across the HV resistor uniform (like your capacitive hoops in the other thread) which simplifies modelling it's operation.
The moment you put a grounded metal shield around it which goes close to the tip the behaviour of the system becomes much harder to predict.
Patrick, Sat Feb 05 2011, 07:42PM
Yes I worry about this. The NorthStar's dont even have sheilding running up torwards the tip at all , just that blue nylon.
Patrick, Mon Feb 07 2011, 05:37AM
The NorthStar's do have a large topand bottom ring, to equalize the field and as you said I guess thats where some capacity comes from too.
I believe the Tek P6013, P6014, P6015 all have that metal shield so they can treat the whole path as a lossy-transmission line?
What about this...
Yellow are copper "Park-like" Caps, Red are resistors. The bottom most section are where compensation and LV componets live.
Patrick, Sat Oct 01 2011, 11:51PM
Ok ive got my silver epoxy so ill make the attempt to fix this probe tonight.
Silver epoxy
Patrick, Mon Oct 03 2011, 10:29PM
Ive come to the conclusion i may not be able to fix this probe. But I have still learned alot so it was worth the 60 USD and teh time lost trying to fix it.
First, the capacitence (3pf) at 60 hz was enough to damp the 10kV sine signal to just 28 mV! through a 99.8 Mohm resistor. And though the compensation box is hard to fix, when my body's stray capacitence was attached to the LV node, the O-scope showed a perfect 17V sine wave. so capacittance does play an enormous role in how these devices work.
I continue the my building of my own probes.
