  • Guests: 17
05/14 hvguy (41)
05/14 thehappyelectron (14)
05/14 Justin (2024)
Giant Wimshurst Machine - could use some guidance
Eleccentric
Thu May 22 2014, 10:44PM
Eleccentric Registered Member #33460 Joined: Tue Aug 27 2013, 06:23PM
I was referring to high voltage collector combs, not the neutralizers. I use the terms brush/comb interchangeably, since either could really be either.
A search of images of Wimshurst machines will reveal that many do not cover the whole breadth of the sector with the high voltage collector. Some use a soft brush in contact with the disc, some use sharp pointed tines of a comb that do not touch the disc.
Antonio
Fri May 23 2014, 01:46AM
AwesomeMatt wrote ...
In the previous post, the end caps for the 5/8" tubing, will that work? I'm not actually sure how to terminate the pipes. I've seen brass balls and stuff, is that too ugly/sharp? Do they need to be spheres?
Will the tubing be enough for the neutralizer bar and comb supports? I was planning on only using the 1" straight pipe for the output rods.
Do the combs actually touch the wheel? Some people said no, but in the tabletop one they do. In the tabletop one both the brushes and combs are made out of solder wick. I was thinking of using photocopier destatic brushes, hovering just barely.
Are the Leyden Jars connected to each other? I think the outer conductor is connected in common?
How thick do my Leyden insulators need to be? I was hoping to use just 4-6" PVC tube, cut however long. So, that stuff is.. I dunno, 1/8"-1/4" thick.
For a very high voltage machine, no sharp corner or end in the conductors can exist. An assembly of balls and tubes works well. The balls can be made of wood, as said, with the tubes in contact inside them.
The neutralizer brushes must touch the disks, lightly but with good contact, or the machine does not start. The charge collectors don't have to touch the disks.
The outer plates of the Leyden jars are in contact. I like to put a secondary spark gap between them. High-voltage pulses appear there when the main terminals spark.
The jars must be thick. About 4-5 mm, probably, is enough. Two jars in series can be used for greater insulation, one inside the other. With tubes you need to close the bottom, what is almost impossible, or just leave a margin as great as in the other direction, with the internal and external plates at the center.
Those nice ceramic insulators can be used in the assembly, if you find how to fix them to other parts.
About mounting the disks on the uper axle, I use a single steel axle, with two ball bearings at each of the bosses, with the disks fixed to the bosses with three flat-head screws. Metal disks can be used at the inner side to avoid stressing the disks, and rubber spacers between the disks and the bosses, allowing some adjustment of the verticality of the disks by the pressure of the screws. I make first the holes in the disks with the exact size of the axle, and once everything is aligned and the screws fixed, I enlarge a bit the hole so only the bearings touch the axle.
To obtain uniform flat disks in acrylic is not easy. Select the plates when buying them, looking for flatness and uniform thickness.
AwesomeMatt
Sat May 24 2014, 03:14AM
AwesomeMatt Registered Member #4454 Joined: Sun Feb 26 2012, 12:47AM
wrote ...
I've seen both styles yes. It's the one piece of the machine I don't really understand how or why it works. How they pick up voltage and what they do.
I've seen the pointed tines, I wondered if they are supposed to be sharp on purpose, or if they should be blunted. Or if actual contacting brushes are easier.
I like the idea of combs simply because, visually, it's different and easier to explain that they have a different purpose.
Today's Progress:
- Got the ugly 2x4 frame and MDF baseplate complete
- Settled on an acrylic thickness at the shop (3/16", 4.75mm)
- Settled on height, drilled out the wheel axle (upper) mount
- Mounted the crank pillow block bearings for the (lower) crank
- Drilled and bolted the 6" pulleys to the 12" ones (12" ones needed some way to afix to the shaft, 6" were bought earlier and were supposed to be returned but under time crunch I'm using those pulleys just as a collar with a set screw).
- Arranged for one friend to lasercut the giant wheels at the local hackerspace.
- Arranged for someone else to use the big CNC Shopbot router to cut the wheels, as a backup plan.
- Figured out a mounting method for the big discs to the little pulleys to the upper axle, and for someone to help lathe the discs (little pulleys are steel, not cast iron, meaning they can be welded, so I'll weld a disc to them, which bolts to the shaft).
- Ordered and rush shipped 4x 5" and 4x 2.75" spheres (thanks Eleccentric for the tip!), it arrives tomorrow.
- Ordered and rush shipped Homemade Lightning book, arrives tomorrow.
My philosophy is that the only tangible reward people get for taking time out of their day to help me, is seeing that their help made a difference. So as promised, I'm making a best effort to document the build in as interesting a way as possible.
Here are the pics I didn't take yesterday. The 6" pulleys ($15 each?) used as collars, bolted to the 12" plastic pulleys (machinable plastic? From some coathangered exhibit).
2003
And the frame as of last night:
2004
Ghetto mounted pillow block bearings ($6 each?). I will have to go back later and bolt them down properly somehow. Or not, it's just a prototype.
2005
Closeup of the large pulleys.
2006
And today's work begins! Lower drive assembly is complete today. A couple pics of it mounted and a handle attached.
That took me a couple hours. The axle did *not* want to go into those bearings. I don't get it, they say "China" right on them, a country world famous for its craftsmanship!
I ended up slightly bending the 1/2" axle trying to hammer it on there with a rubber hammer on a 2x2. Nope. Out comes the 20 ton shop press. Oops, I did it wrong about 1/4 of the way in, flip it around, press it out, start the other way and continue. Took a while to tweak the spacing even preliminarily.
2007
The handle was meant for a 3/4" shaft. It has a set screw, so, some masking tape is working magnificently as a cylindrical shim:
2008
After trying a scribe on a swingarm (worked well but slow), a laminate cutter on another swing arm (melted where I paused to change my grip) earlier this week with moderate success on sample pieces... the 3/8" acrylic arrived today and it was time to put the shopbot to use because computers are faster, right?
2 hours later, we got it to cut (8 minutes total cut time). Had to manually play with some G-code to get it to avoid the center where we bolted that big plate. Took a while to jig up. First time we tried cutting at 6" per second which snapped the bit after a foot. 1" per second with the new bit. Videoed this for later.
2009
Some to-be-repurposed PVC for Leyden jars, maybe, if that's what works.
2010
The gazing globes arrived. I ordered a string of 8 (4 medium 4 small), so they have small holes in them. Bonus! This will help me align them for mounting. Only the tip will need to be filled with a finishing nail ground smooth or something. 5" and 2.75", on a 1" pipe (just laid out, not mounted):
2011
Rollin' rollin' rollin', let's get those big wheels goin'! H'yah!
2012
Quitting shot for the day.
2013
Sat May 24 2014, 10:13AM
You should be able to solder the stainless spheres with silver solder and a strong flux, if required.
Antonio
Sat May 24 2014, 01:10PM
Imagining how you will fix the small ball to the larger one. I would try to avoid solder, but this is an option. The frame seems be too close to the disks. They will spark to the frame close to the neutralizers, if they are set at a high angle. Why the double pulleys below?
Dr. Slack
Sat May 24 2014, 01:43PM
To reinforce Antonio's point. At the voltages and currents involved here, wood is a conductor. If you do a google images search for Wimshurst machines, they *all* have a thin vertical frame that follows the zero potential region up the middle of the discs. The voltage increases to each side of the discs, becoming maximum where the takeoff combs are located. Any significant width on a frame will tend to short out the two sides if it is too close to the sectors.
You may want to rebuild your frame now, so that the diagonal elements become mere corner braces at the bottom, not overlapping the discs, rather than reaching up all the way to the axle. Obviously that's not going to be as stiff as you have at the moment. Then again, you might want to continue this build as is, to get your feet wet, learn whatever else you can at the same time, bearing in mind the sort of rebuild that might be needed next.
Sat May 24 2014, 03:59PM
Antonio wrote ...
I was thinking more for joining the sphere to the copper tube. It is tricky soldering stainless but it can be done.
I've no idea how to join the two spheres, other than drilling two opposing holes in one, and soldering/welding some threaded bar onto the other, passing the threaded bar all the way through both holes in the other, and securing with a nut, and then mounting the sphere with two holes in so that the nut is inside the copper tube. (I can provide a simple sketch if clarification is required.
Eleccentric
Sun May 25 2014, 12:16AM
A thought on the material making the frame: perhaps composite decking boards would be an affordable and much less conductive alternative to wood. I'm not certain of their composition, but it appears to be some sort of easily machinable plastic.
I suppose it would also be possible to braze the stainless spheres together, but it would have to be cleaned up afterward with files followed by progressively finer sandpaper to get back to a nicely smooth surface.
AwesomeMatt
Sun May 25 2014, 07:17AM
wrote ...
Hrm. Crap. I was mostly just scared of 100 pounds of counter-rotating flywheels not being braced like hell.
wrote ...
I had it in my comments... From the first place I went, 6" was the max. Then I found the 12" pulleys in the shop, but they were just bare plastic pulleys, no way to mount them. Since time is an issue, I just bolted the 6" pulleys to the 12" ones because the 6" ones had a set screw.
So, they 6" don't do anything other than afix the 12" pulleys to the shaft. And.. if needed, I could actually use them I suppose, if I wanted a 2x smaller ratio.
wrote ...
I knew this, sort of. It's the reason I rejected plywood or MDF wheels. But I chose to build it this way anyway. I thought it would be a small issue (wood isn't *that* conductive). I see I was wrong.
Again, I was scared of the flywheel energies.
wrote ...
No time to build multiple versions. The need to know if it's a doable project by Friday (working prototype) or they pull the plug and go with something lamer and less challenging (Jacob's Ladder or somesuch).
It's the centerpiece/showpiece of an 8-exhibit electrical thing. The other exhibits you learn things, this is to wow and get people talking.
So, what I will do is mount the wheels and crank them up to speed, get a feel for what gearing is reasonable. When I see what the rigidity is like, I will do as you suggested and chop the diagonals way down to corner braces and see how unstable it gets.
The A-frame is actually almost 4" tall (the upper axle is near the top) specifically so I had lots of wiggle room, so I could still have diagonals going 2' up instead of all 4.
Another thing I will/could do is space the frame out farther on the axles. There is maybe 6" of room between the A-frames, the axles are 18" long. The base is I think 30" wide, so, lots of play room there. The A-frames are built as individual units first, then mounted to the platform, so, moving them is as simple as changing 4 screws.
wrote ...
I understood. I may do this.
Or, I may TIG weld a metal screw onto the bottom of the small one and just thread it right onto the big one. Maybe squirt some JBweld into the hole on the big one before I screw into it and then let the JB weld add some internal support (let it cure upside down so the epoxy cures against the screw inside the ball. The walls are very thin.
Maybe I'll just drill a hole, weld a nut sort of flush, and a bolt to the other globe and screw them in. It's basically the method I'm using to fix the globes to the copper shaft, only I don't have access to the opposite side of the shaft.
wrote ...
Well if it comes down to it, there's lots of scrap acrylic sitting around.
Nylon rope tethered and tensioned to the peaks and corners instead of the diagonal braces could work too I think.
Not much of an update today, was busy doing other things. Homemade Lightning arrived, and I did a couple hours of shopping for plumbing fixtures to solder the copper tubing together.
Thank you all for the continual support, feedback, criticism and interest. Seems every time I get frustrated with an indecision or roadblock someone in the community has come to my rescue.
Sun May 25 2014, 11:23AM
Just a tip, if you do try TIG welding the spheres, I'd drill them and add a supply of argon to the inside, otherwise you'll probably have some problems.
