Registered Member #15
I would put a a pretty high resistance in series. Not sure what your charge source is or what charge times you really want, but on the commercial max generators i've worked with, they generally used 1-10Meg series resistors for this purpose. We also use similar sized resistors when hi-potting large high voltage equipment.
Registered Member #3616
EasternVoltageResearch wrote ...
That's a high resistance value. Looks like another DIY project as finding a resistor capable will be difficult. Maybe a 12 inch plastic tube filled with water and a set of bolts threaded into each end to seal the unit? That should have a meg or 2 of resistance and take the abuse.
What do you think about this as a charge resistor?...
Registered Member #2939
I'd be a bit wary of using a film resistor. When I was working with electric fencing I found film resistors were OK until there was any kind of arc in series with them - at which point they'd blow a hole in the side. Something to do with fast voltage transients I'm guessing. I'd go with the water resistor - its cheap and easy to replace and customise.
While thinking about making a pair of charging resistors (water filled tubes), it came to mind that these definitely need to be on the transformer side of the diode. If the water resistor saw any DC current, hydrogen bubbles would probably form in the sealed tube... not a good thing with so much corona around!
Registered Member #30
Oneironaut wrote ...
Brad
The diode is in series with the transformer winding. It's a series circuit, so if DC flows in one part of it, DC must flow in all of it. Halfwave rectifiers normally aren't used with transformers for this reason: the DC saturates the core. But your transformer is so overkill for the job that it probably won't be bothered.
As to the resistance value, anything above roughly 1k should work, as it just has to damp RF oscillations.
Amethysts are so pretty. You should have found a way to just cleave it, not burst it into a trillion pieces! And where did you get the amethyst anyways?
HighVoltageChick wrote ...
I can't really get into much detail on the specifics, but the client will be happy with the results. In my last version (much uglier design), I removed diamonds and kiberlite from solid rock core (video here)...
This version was pumped by a 14.4kv pole transformer and had some case arcing problems. I am hoping to find funding to purchase 5 new Maxwell pulse caps and make a version that can be used to process tons of sample.
