  • Guests: 18
Cprossu (40)
Kokamo (46)
GalliumMan (60)
12/30 Alex_FX (45)
12/30 Pieznice29 (31)
12/31 Arjan EMM (52)
CCFL mini tesla coil
first  2 3 4 5
Goodchild
Sun Nov 14 2010, 04:47AM
Tesla Fan wrote ...
I have never tried to build anything with these, just have them in my junk box cheesey
1289674749 3353 FT99520 Ccfl 1 Resize
1289674966 3353 FT99520 Ccfl 2 Resize
1289674966 3353 FT99520 Ccfl 3 Resize
oh those look like those supply's for powering cold cathode lighting. not much current there but I bet you could get some decent voltage out of them.
william L
Sun Nov 14 2010, 05:10AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
Actually, I have gotten reasonable amount of current before. You just have to solder across the limiting capacitors , and watch the temperature of the transistors. You could also exchange them for higher power ones.
Tesla Fan
Sun Nov 14 2010, 08:26AM
Tesla Fan Registered Member #3353 Joined: Sat Oct 23 2010, 11:21PM
Well, i found the CC lamp and package of the "large" one (two outputs). Specs claim 400mA power consumption at 12V , so 4,8Watts. Although i know this is a switching power supply and not a simple transformer, i could roughly estimate the output at maybe 9mA (if output voltage is 500V), assuming zero losses. Again, i do not expect much out of a transformer wich is 1,5 x 2 cm...
I would like to give more info, but i am afraid to mess this this PS, as i do not have a voltmeter to measure HV ( over 600V) and maybe this thing gives HV pulses to start the lamp (why else the 3KV cap?), plus i can see no fuse of any kind, so if draw too much current i could blow the whole thing up...
1289723011 3353 FT99520 Ccfl
1289723011 3353 FT99520 Ccfl Specs
Tesla Fan
Fri Nov 26 2010, 06:32PM
Hi,
Grenadier said that "You can get the inductor from a computer PSU", since i live close to Michalis and i have a couple of PSU pcb, can anyone identify a inductor that could work for the ZVS (47μΗ-200μΗ) from these pics? I have no idea how an XμH coil should look like... sad
1290796256 3353 FT99520 Tmp 001
1290796256 3353 FT99520 Tmp 002
1290796256 3353 FT99520 Tmp 003
Adam Munich
Fri Nov 26 2010, 06:36PM
Just pull one of those inductor rings off and wind about 30-40 turns of wire on it.
Myke
Fri Nov 26 2010, 07:04PM
You would want to pull off the largest yellow or yellow and white toroidal core on the board. It's a good idea to wind your own coil onto the core because you can control the number of turns and the wire gauge.
Tesla Fan
Fri Nov 26 2010, 07:05PM
Thanks Grenadier,
I do not want to push it, but which one, the small or the big?I think the small will be a tight fit for 40 turns
1290798336 3353 FT99520 Coil
Adam Munich
Fri Nov 26 2010, 07:09PM
The big one.
Tesla Fan
Fri Nov 26 2010, 07:23PM
Thank you guys!
dingo27
Sat Nov 27 2010, 02:49PM
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Myke wrote ...
... the largest yellow or yellow and white toroidal core ...
is there a difference in parameters between them?
first  2 3 4 5
