  • Guests: 76
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Stories behind the popularity of certain parts?
ShawnLG
Fri Oct 15 2010, 04:46PM
MPSH10 seems to be popular with DIY hams.
2N3904 are used everywhere.
Bjørn
Fri Oct 15 2010, 06:15PM
The PIC16C84 microcontroller also survived a decade and more past sensible retirement because of the google feedback loop.
Common sense also strengthens the feedback because why swhy spend the time and take the risk of finding the perfect part when you can just use something that is proved to work well enough.
radiotech
Sat Oct 16 2010, 05:06PM
One reason the 6L6 was so popular in Europe was the vast quantities of them shipped to Russia when they became part of the Allied Forces in WW2. Those stockpiles lasted for years afterwards.
Prior to Pearl American electronics found many ways to move about the globe as "non-strategic" goods.
Sun Oct 17 2010, 04:12PM
I've not seen many 6L6s over here. We preferred the Mullard/Philips EL34 and the KT66 from M-O Valve. Whether we actually preferred it, or they were just cheaper because they were made domestically, I don't know.
More important than the tubes shipped to Russia was the tube manufacturing know-how. The Russians used it to build their own beam tetrodes, including the one that's now sold as the "6L6GC", which is their 6P3SE.
This also explains why the Russians use the same tube numbering system as the Americans, with a few Cyrillic letters thrown in.
The Mullard trademark, like most of the classic valve/tube brand names, is now owned by the New Sensor corporation, who use them to brand Russian tubes.
Back in semiconductor land, does the TL494 count as a classic yet?
IntraWinding
Mon Oct 18 2010, 03:06PM
These were/are everywhere.
AC128
BC107
BC108
1N4148
Some manufacturers only use components that are manufactured by more than one company to keep supplies secure. That helps keep a popular component at the top of the charts once it gets there.
Lots of Application Circuits from the manufacturer and other design sources that publish help get the snowball rolling in the first place. If a well specified component becomes popular and subsequently its price drops below that of its competitors it's got a hard to beat advantage. I often find several versions of a component from a supplier that appear to be identical from a technical standpoint and then I just go with the flow purchasing the cheapest (most popular) version.
Mon Oct 18 2010, 09:08PM
So, the more popular a part gets, the cheaper it gets, which makes it more popular still, and that positive feedback is what makes it take off and become a classic.
Yes, value runaway. cheesey
/geek
Avalanche
Mon Oct 18 2010, 10:27PM
Steve McConner wrote ...
I've got 10 Russian 6L6s here, actually '6n3c', NOS for my next attempt at a valve amp. Not entirely sure what the equivalent US part number would be, but everything seems to match a 6L6 datasheet I have. 10 should be enough for 1 amp?
TL494 is definitely getting there, probably leading the 3524 which is almost the same!
I always used to think that BFY51 was a noob classic, but that's probably just because it's all I ever used.
2N2222?
Tue Oct 19 2010, 07:30PM
Avalanche wrote ...
2N2222?
yeah, 2n2222 and BFY51 were used since the early 1980's (I used the latter on one of my very first projects..)
talking about prehistoric circuits, has anyone ever heard of the transistor shift register oscillator? i built one a while back (1995!) and adorned a cowboy hat with it, you could enter patterns by shorting base to emitter on one of the stages and waiting until all the LEDs went out..
if i recall that one used the BC548 (another classic) at the time it was one of the cheapest available..
regards, -A
"Bother" said Pooh, as he saw the plot for "Avatar 2" ...
Tue Oct 19 2010, 09:05PM
I'd vote for 2N3819 as the iconic FET.
Wed Oct 20 2010, 09:22AM
Avalanche: That's the 6P3S, which is a lower-powered tube more like the old 6L6G. They're often passed off as 6L6GCs: I have a pair of them relabelled as "6L6GC Made In Russia". But the 6P3SE is a considerably heftier tube. Fender use it in all their reissue amps.
However, I've tried both the 6P3S and 6P3SE in a 50 watt guitar amp, and they both make about 50 watts. Both are available on Ebay by the crateload.
There's always confusion over Russian tube numbers. The "n" is a Cyrillic "Pi" which is sometimes written as P, and the C sometimes ends up as S. You can use this confusion to get crates of them cheap on Ebay. smile
IntraWinding is showing his age by including a germanium transistor in the list of classics. The AC128 was allegedly used in Jimi Hendrix's fuzzbox, so it surely deserves some sort of kudos. (Never mind us 30-somethings discussing tubes, that's different smile )
My favourite transistors are the 2N3904, 2N3906, ZTX651, ZTX751, 2N5551, 2N5401, MPSA42, MPSA92, MJE340, MJE350, MJ15032, MJ15033, MJL3281, MJL1302, MJ15024 and MJ15025. I mostly play with audio circuits, a radio ham would have a completely different set of favourites.
Another "iconic" FET is the 2N7000. Possibly the wimpiest MOSFET in the world, yet somehow it refuses to go out of production. It could be that designers remember it just because it has a nice round part number: there's absolutely nothing else remarkable about it.
Most "classic" transistors and diodes are available in surface mount with a slight change to the part number. For instance, the 2N3904 becomes the MMBT3904, the 1N4148 becomes the LL4148, the 2N7000 becomes the 2N7002. The marketing guys at Fairchild know what the people want smile
