  • Guests: 49
A few questions
1n5ane
Thu Oct 07 2010, 06:14AM Print
1n5ane Registered Member #3283 Joined: Wed Oct 06 2010, 11:03PM
Hey guys,
I've been a long time lurker here (been lurking for the last 2-3 years). Unfortunately, I was preoccupied with other projects and didn't start dabbling in HV stuff until recently. I have been acquiring various components over the last few weeks (flybacks, iggys, mosfets, etc) and I'm looking forward to starting my first HV project. I've done quite a bit of research/reading on various flyback/ignition coil drivers but I still have some questions.
From what I gather, the most frequently suggested flyback driver is the common ZVS/mazzilli driver. I've heard that these drivers eventually "kill" the flyback and/or fry mosfets and diodes. Is there a simple way to improve the reliability of these types of drivers? I'm more of a "reliability/durability" oriented DIYer so killing and frying parts parts doesn't really sit well with me.
Secondly, what would be a conservative voltage to drive an ignition coil at? I'd like to be able to run it for more than just a few seconds (preferably a few minutes) so hooking it up to mains probably won't work for long. This is the circuit I have in mind:
Any and all advice is appreciated!
bgsniper
Thu Oct 07 2010, 08:26AM
bgsniper Registered Member #3200 Joined: Wed Sept 15 2010, 06:57PM
for zvs don-t use high power transistors and don't run it for long. I use irf530 - 79W power transistor. High power transistors will fry the flyback transformer
Thu Oct 07 2010, 08:28AM
As drawn and annotated, the 7812 regulator won't work properly. The 7812 has a 2V drop out voltage, so you will need to feed it a minimum of 14V , if regulated 12V is to come out of it.
So the supply should be +14 - 30V.
1n5ane
Thu Oct 07 2010, 06:00PM
Thanks for the replies! What kind of modifications/component changes are required to run different mosfets on the zvs driver?
As for the ignition coil driver, I am planning to power it off a 12 v supply so I'll probably omit the regulator. I am more worried about frying the mosfet though; is a protection diode necessary?
Thu Oct 07 2010, 06:24PM
1n5ane wrote ...
Then you should decouple the supply for the 555 and the buffer/driver from the final stage in some other way.
1n5ane
Fri Oct 08 2010, 12:39PM
Is there any particular reason why the supplies should be decoupled?
Fri Oct 08 2010, 12:50PM
1n5ane wrote ...
Power MOSFETs like IRFP460 will draw a great deal of current, so unless you have a very stiff supply, it will pull down the voltage every time it conducts, which in turn will affect the operation of the timer and buffer/driver, perhaps causing erratic operation and instability in a way that is not easy to predict.
1n5ane
Fri Oct 08 2010, 03:15PM
My 12v linear supply is rated for 25A continuous and 30A surge; is it stiff enough to power the circuit without problems?
Fri Oct 08 2010, 03:29PM
I still think it would be best practice to separate the supplies in some way, to reduce the chances of interaction.
Fri Oct 08 2010, 05:40PM
1n5ane wrote ...
It could be God's own power supply, and you'd still get voltage disturbances on the supply rail in your circuit, due to the resistance and -inductance- of the wires feeding it. Not a question of If, but How Big? Maybe OK, maybe not. An example where it works fine is the ignition system of an engine.
If there's a problem, it can be mitigated with a large capacitor between the DC rails, as close as possible to the switched-current loops. And/or by filtering the power to control circuit, for example with a simple RC network.
Good luck. This is a case where you can cut corners to start with, and fix where necessary.
