  • Guests: 37
LTX (57)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
First SSTC, Ward's Mini-SSTC Design
Sat Oct 02 2010, 03:33PM
ScotchTapeLord wrote ...
To scope something, you need to ground one side of the load and probe the other. If you ground any part of the AC bit of an H-bridge, you short the top transistor of that leg to the ground!
More importantly, the GND clip of a scope probe is tied directly to EARTH GND through the scope.
Better to measure output differentially using two scope probes.
Use two probes. Set oscilloscope to ADD, and one channel to INVERT. Don't tie GND clips to anything - leave them floating. Be sure not to exceed voltage rating of probe / scope.
Sun Oct 03 2010, 07:14AM
EastVoltResearch wrote ...
For maximum safety when scoping on live circuits I would use a isolation transformer and ground the negative rail on the DC bus. This lowers the short circuit current significantly and might save your ass since most you can easily find are under 500VA, good for low voltage testing.
Russell Haley
Sun Oct 03 2010, 07:49AM
Russell Haley Registered Member #2478 Joined: Mon Nov 23 2009, 03:24AM
When scoping a circuit this way, should the ground leads of the two probes be clipped together?
ScotchTapeLord
Sun Oct 03 2010, 03:51PM
? They're already common.
Russell Haley
Sun Oct 03 2010, 06:20PM
It is my concern that large electric fields could be capacitatively coupled into the shields and then into the center conductors. Clipping the leads together would force any such interference to be common-mode up to twice the frequency of only connecting the shields at one end.
Mon Oct 04 2010, 11:59PM
Mads Barnkob wrote ...
Good point. And keep in mind a variac is NOT isolated. I see lots of individuals hooking up variacs thinking they provide isolation - they do not!
Crunchy Frog
Fri Oct 08 2010, 03:51AM
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Doesn't black PVC have carbon in it and so is unsuitable for TC use?
Fri Oct 08 2010, 11:38AM
Depends what you mean by black. Grey, or electrical PVC is actually better in dielectric strength than "white" PVC.
