  • Guests: 52
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Class-E Tesla Coil working with direct mains power
Mon Sept 13 2010, 01:28PM
The switch in a Class-E amp needs to be able to stand a voltage of at least pi times the DC bus voltage.
The actual mains voltage here in the UK is 240V which rectifies to 340V DC.
Pi times that is 1066V. So you need at least a 1200V MOSFET and those are somewhat rare and expensive.
(Class-E at 4MHz doesn't work with IGBTs, television HOTs etc.)
Luca
Mon Sept 13 2010, 01:59PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Steve McConner wrote ...
I see...
Regards,
Luca
Mon Sept 13 2010, 02:42PM
Looks good.
Although i would use an isolation transformer. That thing is pretty darn dangerous hanging directly off the AC line.
Tue Sept 14 2010, 08:34AM
@Steve McConner: We could use the isolated step downs...
cjk2
Wed Sept 15 2010, 01:42AM
Steve Conner was correct as to how it starts as far as I know. I pretty much just copied Waverider's design. I am using an isolation transformer for testing but I plan on removing it in the final design.
Crunchy Frog
Wed Sept 15 2010, 01:55AM
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
Link2 That's not too bad.
teravolt
Wed Sept 15 2010, 04:07AM
I think this will do
