  • Guests: 71
new drsstc
Goodchild
Wed Sept 01 2010, 05:32PM
Your question about the heat sink is, try it and if it don't work get a bigger heat sink tongue
Gregory
Wed Sept 01 2010, 08:15PM
yeah, i will try, and, is really necessary 800v in a half bridge? oO
Goodchild
Thu Sept 02 2010, 02:16PM
Gregory wrote ...
Yes you should use double the bus voltage for a half bridge, because you only have half the bridge switching. If you had a full bridge you would get 2x Vin out of the bridge because the bridge swings - and + .
You don't have to use 800V but if for example you used a full bridge at 400VDC (very common DC bus for DRs) you would need 800VDC to get the same performance from a half bridge.
Thu Sept 02 2010, 02:44PM
Goodchild wrote ...
Gregory wrote ...
Running at 800VDC gives the price on the complete build a good notch up, doubling up on about all capacitors and I think 1200V silicon tends to cost more than the 600V hardware...
Goodchild
Fri Sept 03 2010, 09:29PM
Mads Barnkob wrote ...
Goodchild wrote ...
Gregory wrote ...
This is true, that is why I suggest building a full bridge.
