  • Guests: 25
Ivan Kalafatic (17)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Torroid making
wannabegeekTC
Wed Aug 11 2010, 04:24AM Print
wannabegeekTC Registered Member #3076 Joined: Fri Aug 06 2010, 07:45PM
hi all
I found a bunch of aluminum dryer duct sitting around my basement...
I haven't figured out how to connect the two ends...i tried soldering it with a propane torch and
promptly burned one up....
Also, how do people connected them in general to their secondary ?
thanks,
wbgTC
Mike
Wed Aug 11 2010, 04:57AM
Mike Registered Member #58 Joined: Thu Feb 09 2006, 05:40AM
Hi,
Go check out a hardware store and buy some aluminum duct tape. Stuff is great and you can use it to not only hold the toroid together but also for smoothing it out to get rid of any possible sharp points besides the main breakout point.
Usually connection might be done via some bolt but depending upon the seriousness of the setup it may be sufficient just to place a good length of the end of the secondary wire (maybe a few inches) and use the aluminum tape to connect it.
Herr Zapp
Wed Aug 11 2010, 06:05AM
wbgTC -
Incidentally, "hemorrhoid" is spelled with a double "r"; "toroid" is spelled with a single "r".
Herr Zapp
Wed Aug 11 2010, 05:02PM
First, cut a wood plywood disk. This will fit inside your ductwork. Easy way to connect the ductwork to the plywood disk is to drill small holes on the outside of disk and then using wire (wrapped around the ductwork at regular intervals) to secure it to the plywood. Probably not necessary for small toroids, but works great for real big toroids.
Xplorer
Thu Aug 12 2010, 03:20AM
Xplorer Registered Member #2416 Joined: Sun Oct 04 2009, 04:23AM
Just use a couple of pie tins....
1
-Tony
wannabegeekTC
Thu Aug 12 2010, 06:04PM
thank you...toroid...
I found some of that Al duct tape ...it sticks great to the other Al ....great stuff
I had some stashed away when some work was done in basment...and I found a PVC pipe !!
I wrapped a new secondary my hand, although the next is going on a lathe at school....
thanks again...
