  • Guests: 45
Eric (53)
HM_Murdock (53)
07/18 Billybobjoe (35)
07/19 Thomas (40)
07/19 VulcanBB18 (50)
Raging plasma, Phil.
Dandrion
Mon Aug 02 2010, 02:02PM Print
Dandrion Registered Member #3045 Joined: Wed Jul 28 2010, 11:02AM
Hello Guys,
Thanks a lot to 4HV.ORG for giving me the opportunity to post my Tesla coil exp't.
Specs : NST parallel 30kv(2x), 30mA@.
Primary coil : 27microH
Primary cap : 4.65nf
Sec. coil : 7.76mH
Res. freq. : 430 khz meas. fr. oscilloscope w/ freq. gen.
Danny Andrion
Manila Philippines
1280757729 3045 FT0 Dsc 0615
Adam Munich
Tue Aug 03 2010, 01:59AM
Wait 30kV?
I would NOT put NST's in series. It is one of the fastest ways to kill them.
Herr Zapp
Tue Aug 03 2010, 02:17AM
Dandrion -
30KV NSTs?
Grenadier -
Who said anything about series-connected NSTs?
Herr Zapp
Adam Munich
Tue Aug 03 2010, 02:37AM
Well the largest NST's i know of are 15kV. To get 30kV you need 2 in series.
Dandrion
Tue Aug 03 2010, 06:55AM
Sorry, yes you're right, it's only 15kv@30mA, I made it parallel to obtain 60mA@15kv. Was able to achieved at least 15" stream.
Also instead of rf ground just hanging below,, noticed that there's 2nd sec. coil. , I tied it in rf grnd & put on top a clear lamp
to clearly see the plasma. Tuning of sec. coil was done w/ oscilloscope & function gen. .Oscilloscope probe was hanged 3" away fr. coil.
while varying the function gen. to get the max. peak volts.
Dandrion
Mla.Phils.
quicksilver
Tue Aug 03 2010, 06:43PM
I also tried the "bowl" top=load you have in the left hand TC & it may be simply the picture but it looks like you're getting some shots at the secondary winding (?) on that one. along with some ring corona on the right hand secondary.
Did you coat the windings significantly? You have some pretty nice output there but repeated shots into those windings may fry them.
I pulled the "bowl" off of mine as I wasn't satisfied that was the best top-load. When used by itself, with a projection (break-out point) affixed to the bowl, are you getting steamers longer than 4cm?
Tue Aug 03 2010, 06:44PM
Thought you were talking about the Phillies!
Tue Aug 03 2010, 07:23PM
You need a bigger primary capacitor!
Dandrion
Tue Aug 03 2010, 10:50PM
Hello quicksilver,
I coated the windings one pass with brush, then dried under the sun. Yes the streamers is more than 4cm. Sparks created bet. 1st sec. coil & 2nd sec. coil is around 14inches.
