  • Guests: 46
old parts?
Myke
Tue Jul 13 2010, 06:46AM
Why not use a triac so you can get the full 0-100% wave? With a SCR, you get 0-50% because like you mentioned, the SCR blocks the current in the other way.
dmg
Tue Jul 13 2010, 06:50AM
I do not have any DIACs on hand (I probably do, just cant find them anyway... im sure I do)
Tue Jul 13 2010, 03:46PM
Myke wrote ...
Agreed, for little stuff like light dimmers. For really big stuff, triacs aren't made, so one uses two or more SCR's.
dmg
Tue Jul 13 2010, 06:58PM
Well, I do have both SCRs and power TRIACs,
I just like to use SCRs over triacs, since I have so many of em, and they are usually higher powered anyway.
in the picture, the SCR is the ratings radiotech has said, 400V 25A. while the traic is the same amperage ratings, so just for the sake of simplicity, Ive desided to use SCRs.
1279047513 2628 FT92600 Triacscr
radiotech
Tue Jul 13 2010, 07:16PM
If you connect the anode of the SCR to the + terminal of a bridge
rectifier and the cathode to the - terminal you can connect an AC
load in series with the input to the bridge. This will act like a triac, handy for big loads.
Use a gate drive transformer.
Adam Munich
Tue Jul 13 2010, 10:15PM
I have some prototype 741 Metal can ICs. Some old metal can transistors too. That's about it.
Oh yeah i have some vacuum glass encapsulated victoreen resistors.
I Love old parts! Whoever doesn't want them, give them to me! I've always wanted a metal can 555 timer. I've also always wanted to build an all-glass circuit. (Glass resistors, tubes, reed switches, selenium rectifiers, neon lamps...)
radiotech
Tue Jul 13 2010, 11:27PM
Some of the first transistors were glass-found in British & German radios made in the 50's. They were painted black-Mullard-Philips-Telefunken- alloyed junction prefix OC.
If paint flaked off light got in and made them phototransistors-so we painted them again.
dmg
Tue Jul 13 2010, 11:51PM
the picture is a diode.... I have more of these parts.. Ill have to look in my junk box for them.
1279065113 2628 FT92600 Glassrec
Adam Munich
Wed Jul 14 2010, 02:46AM
radiotech wrote ...
I must have a glass transistor.
radiotech
Wed Jul 14 2010, 05:38AM
I shall look for one for you meanwhile go here:
finding replacements for audio gear is hard. i found Wireless World May 1965 here and they are for sale in that -- see here-- damn no scanner here ! back in the era ! found a 1958 Popular Electronics
1279085894 2463 FT92600 Feb58poptronics
