  • Guests: 64
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
My new CNC - COMPLETED
first  4 5 6 7
IntraWinding
Thu Dec 30 2010, 07:24PM
Brilliant stuff! It looks extremely solid. What sort of RPM will this run at and what factors led you to choose forced oil cooling?
Dr. H.
Thu Dec 30 2010, 09:08PM
Good day guys
thanks for the kind replies smile Yep it is built to last.
I've decided on forced oil because that is the manufacturers reccomendation for those types of bearings. They are sad to work at 12k RPM. The motor I am using is capable of runing it up to about 6k RPM (looking for a bit bigger/faster motor). But in most cases it will be running in the range of 2k RPM. Also from past experience with spindles they tend to get quite hot after a while under hevy loads and high RPMs.
P.S. Working on a power supply for the spindle motor in the moment. Pics soon.
Cheers smile
IntraWinding
Mon Jan 03 2011, 02:09AM
I was comparing it to my mini lathe headstock which uses grease. It looks similar but only runs at up to 2500rpm and the lathe's only manual. Do you use a preload of some sort on the bearings?
Dr. H.
Mon Apr 04 2011, 05:50PM
Good day guys
I was 4 days home so I had a bit of time to work on the project. I've built a power supply to run the spindle motor. I've used what ever I had on hand. First run is approaching smile
IntraWinding - sorry for the late reply - I've missed your post - yes there is a nut on the shaft to adjust the preload.
Cheers smile
1301939400 931 FT92565 Pic 7259
1301939400 931 FT92565 Pic 7260
1301939400 931 FT92565 Pic 7262
1301939400 931 FT92565 Pic 7270
IntraWinding
Wed Apr 06 2011, 12:41AM
Do you have an estimate of when it will be ready to test?
Dr. H.
Fri Apr 08 2011, 07:15PM
Good day Intra
most of the stuff is ready (I am "fighting" with the electronics in the moment and that is the last big thing left). I really hope to get it going till the beginning of the summer (I am not home and can't work on it a lot - only in the weekends when I get home).
P.S. But sure is fun to be able to work on the electronic stuff if the dorm hee hee cheesey
1302290118 931 FT92565 Dsc01902
Dr. H.
Tue Apr 19 2011, 07:22PM
Good day guys
after quite a bit of work the electronics are finally ready. All of the safety features are working and the servos are turning fine now. I've finally got one axis of the mill moving but there is still a lot of tuning to be done on the servos. Hope to get all of the axis working in the next few days. First cut is in sight cheesey
1303240922 931 FT92565 Pic 7272
Dr. H.
Wed Apr 20 2011, 07:00PM
A fast update
I've spent most of the morning and big part of the afternoon fixing a problem with one of the axes - it is OK now. I've mounted the spindle and wired the limit switches. Also tested the power supply for it for about 30mins ... no problems there smile Tomorrow I have more work to do on the Y (mostly adjusting things and fixing small problems).
Cheers smile
1303326034 931 FT92565 Pic 7283
Dr. H.
Thu Apr 21 2011, 05:48PM
FIRST CUT wheeeee amazed
after almost 9 months of build time it finally started cutting cheesey A few problems have shown up but nothing critical. I've spent about 3 hours testing different tools and different feed speeds and RPMs - starting to collect data smile. I was amazed how well it handled 8mm end mill at 100/min feedrate and 1mm deep groove in aluminum - it cut really nice. No real code for now - just a fast test program I wrote to cut a square out of plexy. Other tests were done with manual feed on the PC.
things remaining -get the cooling system working
- get the oil system working
- build an RPM meter for the spindle
Cheers from a very happy Dr. H.
1303408124 931 FT92565 Pic 7295
1303408124 931 FT92565 Pic 7296
1303408124 931 FT92565 Pic 7297
Thu Apr 21 2011, 06:27PM
Huben,
This has been one of the greater projects this and last year, and you are the man!
No end to the fine curved parts you are going to spit out from now on!
A "Hats off" from this Danish Toolmaker.
Cheers, Finn Hammer
first  4 5 6 7
