  • Guests: 51
muller (38)
Dr. Mario (38)
Ben Solon (30)
01/28 LTX (57)
01/29 IAmSpock (18)
01/30 Ian (37)
My new CNC - COMPLETED
Mon Jul 19 2010, 08:26PM
Thats looking nice, good job recycling wink
What are all of the analog meters for?
Dr. H.
Tue Aug 17 2010, 04:49AM
Good day guys
Hi ... - the meters are for the servo motors and for the spindle.
It's been a while since I posted but I was absent for more than 10 days and the work on the CNC has been slow... but we've picked it up again.
Pics of the progress - all of the mechanical work on the electronics is done, time for wiring. Yesterday we've got the table done (the slides for now). I hope in a couple of days to mount the lead screw and the motor.
Also we've started working on the spindle - pics of it soon.
Cheers smile
1282020579 931 FT92565 Pic 7167
1282020579 931 FT92565 Pic 7169
1282020579 931 FT92565 Pic 7165
Killa-X
Tue Aug 17 2010, 05:21AM
Looks great! Lots of parts, should be a good CNC machine! I got mine on hold, yet I know where to get all my parts finally.
Hope you can get it running up soon, Be nice to see how it runs :D
Dr. Drone
Tue Aug 17 2010, 04:24PM
shades
Dr. H.
Tue Sept 07 2010, 06:45AM
Hi guys
it's been a while since I last posted but a lot of work has been done on the mill. I got the servos running, the wiring of the electronics is 90% done, the Y-axis is almost completed. Last night we did some test and it reached 60 inch per minute but at half the supply voltage. So 80 even 100 inch per minute should be reachable.
Working on the covers and protective "belts" for the linear guides now.
Here some pics
Cheers smile
1283841910 931 FT92565 Pic 7176
1283841910 931 FT92565 Pic 7178
1283841910 931 FT92565 Pic 7189
1283841910 931 FT92565 Pic 7190
Tue Sept 07 2010, 07:10AM
NICE! a bridge frame too!! ive never used graphite-PTFE, how strong is it? if your spindle binds, will they strip!?
(PS look everybody ive got my sixth star!!!)
Tue Sept 07 2010, 08:19AM
Very professional looking :)
Good craftmanship in hobbies and thoughtful construction is what makes a special project, looking forward to see some serious milling!
Dr. H.
Tue Sept 07 2010, 06:05PM
Hi guys
thanks for the kind words smile
The PTFE is quite hard. This one is specially designed for industrial air compressors(for the segments) .
We had a small incident - a screwdriver got between the support of the linear guide and the linear bearing - it got bent without even noticing it (and it is 6mm thick).
Also the nuts sit in a "clamp" - if the load becomes too great - they slide out of it. This was tested by deliberately "jamming" the axis - it worked perfectly.
Here are the pics of today's progress smile
Cheers :)
1283882720 931 FT92565 Pic 7191
Wed Sept 08 2010, 12:37AM
Dr. H. wrote ...
Cheers :)
you do good work Dr.H
also, do those blue plastic sheets roll and unroll as your quill moves? how did you make those?
rp181
Wed Sept 08 2010, 02:12AM
I am trying to figure out the purpose of the vertical blue sheet. The bottom one is to trap waste I assumed, but I can't think of a use for the vertical one.
