  • Guests: 21
Ivan Kalafatic (17)
10/06 Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
Problems with my DRSSTC
hv-friekie
Tue Jun 15 2010, 03:23PM Print
hv-friekie Registered Member #2273 Joined: Thu Aug 06 2009, 07:02PM
Hey Guys,
At the moment, I'm testing my big DRSSTC again.
It has a fullbridge with 20n60 igbt's and uses the schematic from CTC's DRSSTC 6 (Link2 go to Projects>DRSSTC 6).
The secondary is 15cmX50cm with 0.3mm wire, the torus is 15cm thick and 40cm in diameter.
But I ran into the following problem:
Everytime I turn my interrupter on, it gives me a streamer into the air which is about 23cm long (on 100V).
But this streamer is only a short pulse, after this I don't get any streamers into the air!
It only gives me sparks to ground.
I don't know where the problem is.
Has anyone a good idea? smile
Edit: Without the Toroid i get around 14cm streamers into the air.
hv-friekie
Wed Jun 16 2010, 02:57PM
I fixxed the problem, thanks for your help...
