  • Guests: 32
  • Most ever online: 441
Avalanche (42)
10/02 Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
Magnetic levitation
Petezel
Tue Jul 18 2006, 02:58PM
Petezel Registered Member #211 Joined: Sun Feb 19 2006, 05:33PM
Hey, nice work!
Link2 < have a poke at that, a clock where the display section 'floats'
Regards,
Pete
Sun Oct 15 2006, 07:27PM
I just built one of these except I chose to use an infrared beam for object detection. One photo-transistor detects background and LED light while another detects whether the beam is broken. These two are compared and the result goes through a lead compensation circuit much like cjk2s. This signal then gets amplified and this controls the electro-magnet. Quite simple but once I got it running it was very stable with both heavy and light objects.
Things I can improve on it are the need for dual supply, overheating of drive transistor and make a proper housing. Otherwise it would be mantelpiece worthy!
1160940466 95 FT9059 Magnetic Levitation Uzzors
teravolt
Sun Nov 12 2006, 03:29AM
Tesla Down Under what does the rest of your levitating shaded pole motor look like
Tesladownunder
Sun Nov 12 2006, 05:51AM
teravolt wrote ...
Nothing shady about my poles.
Not quite sure what you mean? Details here.
I now have an electromagnet that will support a NIB magnet at 17cm height with about 500W input power. This is compared with about 10cm max with the old magnet pictured below.
The new one is based on a cut down 2KVA 250 to 110V transformer.
Pic below is the old one.
Peter
1163310662 10 FT9059 Maglev2coil
Wed Nov 15 2006, 04:13PM
Here is a circuit I designed, do you think it will work?
1163607195 152 FT9059 Maglev
Fri Nov 17 2006, 04:18PM
Due to the lack of catch diode across the magnet, I expect it would "A splode". Also that stuff about the TL494 needing pull-up or pull-down resistors on its outputs (can't remember which) and you forgot to put bypass capacitors on the supply rail too.
Fri Nov 17 2006, 06:13PM
Jmartis wrote ...
The quickest way is to simply try it.
Fri Nov 17 2006, 08:28PM
Steve Conner wrote ...
thanks, so I built a circuit with these modifications, and by principle it works, but it is not stable (the levitated object sticks to the electromagnet above it)
Fri Nov 17 2006, 08:32PM
With such 'flyback-ish' drive mosfet is surely going to absorb some HV spikes and heat up, but it probably won't blow up unless you push the frequency very high and power hard.
Putting diode or TVS across mosfet will just move the heat to another place, but that's probably the point.
Halfbridge drive would be much more efficient solution fr this.
Regarding pullups, with just one mosfet they aren't needed; just connect pin 10 to ground and pin 8 to mosfet, so you use TL's output transistors in push-pull.
Sat Nov 18 2006, 09:14PM
Jmartis wrote ...
Did you see the earlier posts that mention the need for a lead compensation circuit to keep it stable?
BTW, merovingian mentioned the risk of "Flux Walking" in the magnet. Flux walking is exactly what you want in this system! It's the DC magnetic field that does the levitation. The controller walks the flux up to whatever level is needed to keep your object hovering at the desired height.
Any AC ripple at the switching frequency is just a nuisance. In practice due to the high frequency and high coil inductance, I expect there would be hardly any ripple, which explains why it's hard to extract power by magnetic coupling.
