  • Guests: 66
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
New supermagnetic material is 18% stronger than any material so far
Sat May 29 2010, 05:19PM Print
Great Scott! Shades of magnesium diboride...
Is it just me or would such a material if stable be useful for building high efficiency motors.
Note, nitride chemistry, same as high efficiency LEDs.
-A
Sun May 30 2010, 09:43PM
Probably yes, if it could be made in bulk instead of thin films.
I'm pretty sure the exceptional property is a large SATURATION FLUX DENSITY,
which means it would make good flux-concentrating pole pieces, not permanent magnets.
It took a while to interpret the expression "most magnetic" in the lay article.
First hint was where it says "predicted that iron-cobalt should be the most magnetic material." That points to soft magnetic alloys like Permendur / Hiperco, which saturate at about 2.3 teslas.
It's further clarified by the "more information" link, which is an abstract of article titled " Origin of Giant Saturation Magnetization in Fe16N2 thin film". That suggests that as long as the stuff is being magnetized by an external field, it develops an extraordinarily high magnetic moment per unit volume.
Might someday be valuable for magnetic disk data-storage technology.
Mon May 31 2010, 10:49AM
This would be good for the slotted toroid idea
IntraWinding
Wed Jun 02 2010, 01:28AM
I think it's a sad state of affairs when science press releases are so hyped that even the technically literate struggle to work out what the real 'advance' is supposed to be.
Wed Jun 02 2010, 09:14AM
New press release is 18% stronger than any blurb so far!
tongue
Thu Jun 03 2010, 03:30PM
How many mistakes can you see in the penultimate sentence of original news article?
"If the magnets can be manufactured commercially they could allow computer manufacturers to use smaller write heads that could hold more information. "
