  • Guests: 40
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
first tesla coil/questions
first  3 4 5 6
aris
Fri May 28 2010, 04:07PM
aris Registered Member #2871 Joined: Sat May 22 2010, 06:50PM
DSCN0057
Is this circuit ok?I think to wire my one feedback coil as the picture....Also i think to use a thermal grease to cool the transistor this will be ok?!!!
quicksilver
Fri May 28 2010, 04:18PM
A 9V battery puts out less than an amp (it's a collection of smaller batteries within). Therefor I doubt that you'll have heat issues. I'm looking a an alkaline 9V & it is .850ma. Unless that arc was maintained for quite awhile I doubt that the transistor would heat to a problematic degree. Don't expect an arc over a centimeter & remember that the battery will wear rather quickly thus giving you less and less current, etc.
The above is fine for understanding the elements needed to utilize the flyback but as it is, I believe that you'll need to be satisfied with watching a mild, short, thin, blue arc. To drive a TC you'll need something a bit more robust. But you will learn that as a process by doing the above construction.
ScotchTapeLord
Fri May 28 2010, 05:03PM
Maybe you could try to get hold of a sealed lead-acid battery. That's what I use for my flyback drivers. They can put out enough current and can be recharged, and it is only slightly higher voltage than a 9V.
aris
Fri May 28 2010, 08:51PM
Scothch how much amber output a sealed lead-acid battery?!!
Fri May 28 2010, 09:28PM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
well its a peak amp. in theory a car lead-acid battery can output 100s of amps, but the kind you find in flashlights, 10s
ScotchTapeLord
Fri May 28 2010, 09:31PM
I would guess it depends on the size of the battery. I've mostly used ones from alarm systems, which I believe were 7 Amp-Hours, meaning in theory that it would last an hour under a load drawing 7 Amps. I don't know for a fact that it is capable of reliably supplying 7 Amperes, but it probably can (with ease). I have probably drawn up to 3 or 4.
Sat May 29 2010, 10:01AM
Those SLA batteries can supply plenty of current. If you short one by accident, you can melt the insulation off the wires and burn yourself.
That is, assuming they're not old and worn out.
aris
Sat May 29 2010, 01:05PM
DSCN0058
This feedback coil is 4 turn of 22AWG wire...The wire is wedged on the ferrite core,there is any problem with this?
Also can i use thermal/heat paste(processor's one) for the transistor?
Sat May 29 2010, 01:30PM
yes, but why would you need it? you are not going to heat up the transsistors. We arn't known to be nice to semis or tubes:-D
aris wrote ...
DSCN0058
Feedback winding is looking fine and normal thermal paste is good, there is no special transistor paste, and if there is, its not worth the money for our hobby :)
first  3 4 5 6
