  • Guests: 71
Need idea for SGTC
first  2 3 4 5
tulkas
Tue May 25 2010, 06:25AM
tulkas Registered Member #2865 Joined: Tue May 18 2010, 10:59AM
TNX . i'll put it in oil .(is frying oil(or what we eat)good for that?)
no Houston(Hudson) street's lab caught fire.
our standard voltage is 220 VOLTS . if i use a variac and send more than 220 (like 250 or 300 ) volts into my NST is it going to hurt it ?
tulkas
Thu May 27 2010, 12:35PM
this is my first safety gap .
i hope it going to works.
it's something i must ask : when i short my NST the sparks are at least2 or 3 CMs but when i use caps in series with NST the spark becomes smaller but more powerful . is it right ?
isn't here anybody to comment about ultra coil in previous page ?
and please tell me about the previous post and what happens to original tesla's coil .
1274963715 2865 FT89391 Dsc00868
dmg
Thu May 27 2010, 01:59PM
I think for your safty gap, you should probably consider using electrodes with balls on the ends of them, it will be more effective as a safty gap.
main reason for my thinking is that that gap you showed in the picture has fairly pointy ends, and might have corona more then when compared to ball electrodes, and that may cause misfires in the safty gap (it shorts when its not supposed to).
Unforchantly, Ive got no clue about tesla's original coil.
tulkas
Thu May 27 2010, 04:33PM
you mean if i flatten ends of electrodes it will be better ?
well i don't have anything in ball shape what should i do now ?
Thu May 27 2010, 08:42PM
Get some end nuts that you can put on a piece of m6 thread. Those will work.
tulkas
Fri May 28 2010, 06:07AM
can you explain more please ?
Fri May 28 2010, 10:45AM
These Link2
tulkas
Sat May 29 2010, 02:37PM
what about these ?
i tested it and it works .
1275143876 2865 FT89391 Dsc00869
1275143877 2865 FT89391 Dsc00873
Sat May 29 2010, 07:30PM
Should suffice
tulkas
Sun May 30 2010, 04:17AM
Thanks.
So I'll use that .
first  2 3 4 5
