  • Guests: 35
Combined Plasma speaker, and Plasma Globe
voyagerscout
Mon Apr 19 2010, 10:00AM Print
voyagerscout Registered Member #1696 Joined: Sat Sept 13 2008, 06:01PM
Hello everybody.
If you hook up your plasma speaker to a plasma globe, would you still hear some music?
I build my plasma speaker at school, and well, it is finally finished.
But my teacher is afraid someone might be stupid enough (read, interested :P) to touch one of the leads.
So I had to come up with a solution to make the speaker fool proof, and i wanted to find a solution to get rid off any ozone created by the "spark".
I thought a plasma globe might solve the problem.
Many thanks!
Mon Apr 19 2010, 01:48PM
You're not going to hear much through a glass plasma globe. Sounds like your teacher is concerned about safety. In that case, just enclose your plasma speaker inside a cage of mesh wire (available from any hardware or home improvement garden center).
Plasma globe would also work, but you're defeating the purpose of your plasma speaker.
voyagerscout
Mon Apr 19 2010, 02:21PM
A cage of mesh wire might be a good idea^^ The cage should be connected to a proper ground, right?
But that still leaves the Ozone problem. Is there any way i could minimize the ozone production?
I read something about using a hydrogen and oxygen flame, to make ionized "air". This way the only byproduct would be water. Could this maybe work?
EEYORE
Fri Apr 23 2010, 09:11PM
I believe ozone is only dangerous in high levels. Open a window in the room it is in. Ozone can be beneficial in small amounts.
As for the wire cage, you will want it connected to a good ground.
As for dealing with stupidity, youll want a good lawyer. wink
Matt
Antonio
Sat Apr 24 2010, 12:08AM
Ozone and other nasty gases produced by sparks are not something to ignore. The irritation in your nose, eyes, and even ears can last for several days after just a few minutes of experimentation with high-voltage devices. Ventilation is an absolute necessity. I don't know of any efficient way to avoid ozone formation, other than the elimination of oxigen from where the sparks are produced.
lpfthings
Sat Apr 24 2010, 12:48AM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
For something small like a plasma speaker arc, just a simple fan should be enough. I've found that the ozone is mostly produced when the arc doesn't have a return path, and just sits there hissing.
Avi
Mon Apr 26 2010, 04:28AM
If the current is increased such that it a hot arc, i have found that I can not smell the ozone. Perhaps it burns it up?
Mon Apr 26 2010, 04:30AM
Avi wrote ...
Or does the voltage drop too much to create ozone? But then, even if the voltage was somehow high enough, saw 12kv, would it just be burnt up?
GhostlyFigures
Mon Apr 26 2010, 09:32PM
GhostlyFigures Registered Member #2385 Joined: Thu Sept 24 2009, 01:26AM
Location: Waxhaw, North Carolina (Or Charlotte near UNCC)
I don't believe the Ozone created by the flyback stays ozone very long. In fact most of this type of Ozone stays at a lower altitude and is a component in smog or pollution. I think I have read somewhere that it's unstable and the O3 eventually goes back to regular oxygen.
Mon Apr 26 2010, 09:39PM
yes the half life of Ozone dependes on many factors, some accellerate its decomposition, others lengthen time need to decompose.
