  • Guests: 54
Pll SSTC- unfinished yet
Pylon
Tue Apr 13 2010, 06:00PM Print
Pylon Registered Member #2065 Joined: Sun Apr 05 2009, 06:32PM
Some time ago i wound secondary and build antena feedback driver same as Steve Ward's mini sstc driver. The sstc isn't working and i dont want to figure out what is the problem so i decided to build a Steve Conner Pll driver. Pll driver works wery well so i want to finish this sstc. I tested it with half-wave rectification, CW mode and audiomodulation works great too :).
Now i going to make new board with AND gate for interrupter input. I going to increase power by decreasing number of turns- now its around 500W but will be much more.
http://www.youtube.com/watch?v=Nemu2clIMHY&feature=channel - audiomodulation test
secondary and primary
Sstca
CW mode 330uF filtration
Cwwwwwww
Halfbridge
Hbridge
Tue Apr 13 2010, 07:13PM
Nice, but where does the yellow GDT core come from? A PC power supply? (if so I'm surprised it works at all cheesey )
ManiaC
Tue Apr 13 2010, 07:35PM
ManiaC Registered Member #2763 Joined: Sat Mar 27 2010, 11:48AM
big coli and a tinny arc :)
I have a PLL driver and 10-cm coli , the input power is around 150W
and it have a larger arc
I use to interrupt a INH pin on CD4046
GDT look like from PC power supply with a iron core
Pylon
Tue Apr 13 2010, 08:01PM
Good idea, does it works properly?
This is not core from ATX this it is 3e25 material core, good material for GDT's http://www.ferroxcube.com/prod/assets/3e25.pdf
Yes, arcs are not big now (about 15cm) but this is a first run i have to many turns on primary. For audiomodulation video i made discharges smaller for better audio quality.
Tue Apr 13 2010, 09:20PM
I always enjoy new sstc threads :D.
I like the secondary and primary, nice job.
But, i do have a few concerns. First of all, the GDT to mosfets should have much smaller leads! That is way too long, at least in my opinion! I normally keep it to an inch or two 'round trip. Another thing, the 10 ohm gate resistor does not need to be that big, and it has to be carbon film or some other film. That one is a ceramic wirewound, and the wire has some inductance. Just a little 1/4 ohm resistor right on the gate should be fine, with the GDT as close as you can possibly get it. There is no need for an entire circuit board for the resistors and zeners, right on the device leads is perfect. Also, try to get the wire on the GDT tighter, so that it is closer to the core. Every little bit reduces leakage inductance!
With a sstc i made, with class E switching, i tested the gate wavefroms with my scope. I tested the waveform right at the ucc3732x, and then an inch away. The ringing was noticeably worse, but completely negligible. Surprisingly, it was the amplitude of the ringing that went up, not the number of cycles... Shorten everything up!
Looking forward to seeing more progress!
Herr Zapp
Tue Apr 13 2010, 09:23PM
Pylon -
You might want to read the Ferroxcube Design Guide for Gate Drive Transformers (Link2
This will help you select the correct core material and winding inductance for your coil's frequency range.
Your 3e25 core material seems to be intended primarily for use in RF noise suppression chokes.
Herr Zapp
Pylon
Tue Apr 13 2010, 10:02PM
->Herr Zapp
I know that this is not material designed for GDT's but it work very well as GDT (checked with oscilloscope)
->Arcstarter
Yes, this wires are too long sad (first i mounted everything on polywood and then i connected everything with wires).
Fortunetely it's works.
For sure my next bridge will be much much beter wink (fullbridge i looking for some nice heatsinks)
raff
Wed Apr 14 2010, 04:06AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
Pylon wrote ...
->Herr Zapp
would very much like to see it in your next bigger/fullbridge SSTC cheesey
Pylon
Tue Apr 27 2010, 09:24PM
Now my sstc waiting for softstart circuit. I have tested CW mode with 1500uF filtering cap- nice hot arc without cracking, that would be nice plasma speaker cheesey.
Some new pics:
Overview
Th
Half-wave discharges
Th
Pylon
Wed Mar 30 2011, 05:15PM
Hi again cheesey
Now my sstc have soft-start circuit, filtering capacitors, and good working audiomodulation.
So i'm going to build final version of sstc driver.
