  • Guests: 39
Relating frequency and voltage
Thu Mar 18 2010, 11:11PM
The more you increase frequency the more drive power you need for the same voltage output, because the capacitive current from secondary top to the surroundings increase and spark "thickness" and temperature increases.
So if you wanted to design a coil with say 1MHz frequency and 1MV output, you might as well end up with megawatts of input power. On the other hand, 1MV at 50/60Hz produces just a bit of corona.
So I would say that theoretically everything is possible, practically not, because with increasing frequency you need to drop the voltage for the same power.
EvilTesla-RG
Fri Mar 19 2010, 01:18AM
EvilTesla-RG Registered Member #1523 Joined: Sat Jun 07 2008, 02:05PM
Ah.
I see. So increasing power will increase the spark length per frequency
dex
Fri Mar 19 2010, 10:59AM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
EvilTesla-RG wrote ...
Yes, but how are these bounds related?
What I really want to do, is create an equation that relates frequency and voltage approxamatly.
So that if we have a frequency X, and voltage Y. Where it is quite possible to build a Tesla Coil at frequency X and a Tesla Coil at Voltage Y.
Y^2 ~ 12.56*P*L*X
P=peak power,L=secondary inductance
Fri Mar 19 2010, 11:19AM
I guess that's correct, but you should also be aware that L is related to the frequency.
If we say that C is roughly constant because stray capacitance places a lower bound on it, then:
f = 1/(2*pi*sqrt(LC))
hence for C constant, f is proportional to 1/(2*pi*sqrt(L))
square both sides: f^2 is proportional to 1/(4*pi^2*L)
dex's proposed equation:
V^2 = 4*pi*P*L*f
= (1/f)*4*pi*P*L*f^2
substituting:
V^2 is proportional to (1/f)(4*pi*P*L)/(4*pi^2*L)
cancelling out stuff:
V^2 is proportional to P/(pi*F)
since it's proportional, we can just toss out the factor of pi too
V^2 is proportional to P/F
So (assuming dex's original equation was true :) ) the higher the frequency you want, the more power you will need to produce a given voltage. If you want twice the frequency, you need twice the power.
I used this PSpice simulation set: Link2 to simulate DRSSTCs, along with the old FANTC simulator to work out the coupling and resonant modes.
dex
Fri Mar 19 2010, 11:45AM
L in the equation is a "low frequency inductance" . Sometimes it is called DC inductance of secondary.It can be easily measured or calculated.This value of L is quite a good represantative of a 1/4 wave resonant coil terminated with big toroid.OTOH,corresponding self capacity (C) is problem to measure or calculate.It differs much more from low frequency C value in the equivalent equation.That's reason why is L more convenient parameter to use.
EvilTesla-RG
Sat Mar 20 2010, 02:56AM
Ah!!
Very interesting, thanks!!
This is pretty much what I was looking for.
