  • Guests: 70
beginning of my third plasma speaker.
ScotchTapeLord
Wed Apr 07 2010, 04:41AM
If it's inrush current you could try a resistor in parallel with a relay (or, better yet, a on-resistance FET on the DC supply) in parallel, triggered a few mS into operation.
tobias
Thu Apr 08 2010, 02:46AM
tobias Registered Member #1956 Joined: Wed Feb 04 2009, 01:22PM
Do you have a way to measure the inrush current?
The FETs still good?
Good luck resolving this problem! Good to know that it turned on =)
How was the sound quality while working?
GhostlyFigures
Thu Apr 08 2010, 03:45AM
GhostlyFigures Registered Member #2385 Joined: Thu Sept 24 2009, 01:26AM
Location: Waxhaw, North Carolina (Or Charlotte near UNCC)
The spark was very small so I really couldn't hear anything really, I only had it on for a couple of seconds. The Fet was a little warm but the heatsink I used isn't very large. I don't have anything to measure inrush current unless I reduce it and used the oscilloscope some how. I was hoping to just find out which type of power supply is best. It's possible that here is something wrong with the flyback since I've used the same one in my past designs in which I've heard some arcs near the bottom of the Flyback. I did insulate it tho so that wouldn't be much of a problem now. I'll have to wait til I get home Friday afternoon to continue testing. Im also wondering if something on the board or if the material im using for the anodes is causing it to draw a lot of amps. The number of turns on the primary is 12 turns I believe its 20awg because there isn't much space between the core and the flyback.
tobias
Thu Apr 08 2010, 01:32PM
I use a 30 V 3 A PSU, but my plasma speaker only consumes 2 A. My PSU has current limiting and it limits to 3 A the initial current. But the plasma starts anyway.
I would use the 24 V 3 A.
GhostlyFigures
Tue Apr 27 2010, 08:16PM
I found the problem, or at least what caused it to stop working. A trace had burned completely in half probably because of high amps running through it. I didn't think the trace would ever burn up but it did, it also ruined the 540 and since I didn't see that when i went to test it again It blew one of the MUR diodes :)
GhostlyFigures
Fri May 07 2010, 07:44PM
Ok so I fixed the problem and the FB produces a stable arc but i don't really hear the music, I hear some of it and it sounds a little muffled but mostly noise and screeching. I adjusted the frequency and all that but I don't know why it sounds so bad. Would having the audio backwards cause a problem? I have to get another 7812, I accidentally blew that too :)
tobias
Tue May 11 2010, 10:36PM
Are you using heatsinks on the diodes? You can´t connect the two diodes and the mosfet together by the heatsink or they will aways blow up.
Do you have a oscilloscope to test some points on the circuitry? If the 7812 blew up probably the TL494 and the fet drivers are gone too!
Wed May 12 2010, 08:12AM
Remember that the resistance of solder is about 10 times greater than copper, so if you have a high current track completely made out of solder, it is likely to melt as the solder also have a lower melting point.
The more copper you can keep in your power section of the board, the better, also you polute your etching solution with less copper. I used to draw my boards with a sharpie, but switched to toner transfer, its superior in all the ways possible, just get some glossy paper from a copy store, some colors from magazine paper will transfer too, I had problems with green and red.
