  • Guests: 58
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
ZVS driver help! 24v 50A psu zenners ????
Ed
Fri Mar 12 2010, 10:21PM
Ed Registered Member #2721 Joined: Fri Mar 05 2010, 04:09PM
ezis, i have seen schematics when this is fed from rectified mains, what would be the top voltage to use with these zeners, or is there a way to use other type of regulation on the gates, mabe a separate psu ?
thanks
ezis666
Sat Mar 13 2010, 08:12AM
ezis666 Registered Member #2564 Joined: Tue Dec 22 2009, 05:26AM
And try searching forum archive
Ed
Sun Mar 14 2010, 05:27AM
Hello,
Hey, today i fried 2 more mosfets,
this time i purchased an osciloscope to monitor the gate signal and a freq meter to see check the output freq,
i noticed that signal peaks at about 25v so guess this is bad,
however it worked quite nice at around 30khz, trying to increase frequency i changed the capacitor to a lower value and while frequency went up to 39khz, i noticed some oscilations at the gate when voltage almost come to zero, changed capacitors again, and this time the gate drop ocilations where much larger in time and amplitude, and circuit inmediately died before i could measure freq.
any toughts
Thanks
ezis666
Sun Mar 14 2010, 03:13PM
25V at gate-source? have You zenerdiode installed correctly?
What mosfets?
IRFP450 to big Rdson
Ed
Sun Mar 14 2010, 09:42PM
Yes, IRFP450, but they dont get hot,
zener unregulated V=45V and gate input (after zener) 25v Peak
i just got two NTE2943 Rdson 0.077ohm but mag DtS 100v
ezis666
Mon Mar 15 2010, 06:05AM
Most mosfets have 20V MAX s-g voltage. Try 12V zeners&470ohm resistors.
NTE2943 is only 17A.
I need see your schematic
Ed
Mon Mar 15 2010, 02:00PM
my schematic is same as yours, from Vladimiro Mazzilli
Thanks
Ed
Tue Mar 16 2010, 09:08PM
any further advice on this ???
would a large vcc capacitor help, or some resistors on the gates ??
HELP !!!!!!!
Mhavskie
Wed Mar 17 2010, 02:41AM
Mhavskie Registered Member #2643 Joined: Wed Jan 20 2010, 08:33AM
This is my ZVS Flyback driver Zvsflybackdriver
Myzvsschem
Wed Mar 17 2010, 03:56AM
Ed, just use your working ZVS driver. Wind the 10 center tapped turns on one side of a large (if possible) LOPT core, and on the other side try different secondaries. Use around 12 gauge. Try 5 first, then just experiment. Mess with the work coil, try 3-10 or whatever.
