  • Guests: 40
Anyone own one of these?
lpfthings
Sun Feb 28 2010, 12:44PM
lpfthings Registered Member #1361 Joined: Thu Feb 28 2008, 10:57AM
Erm, yeah, that makes sense!
Thanks smile
AmonRa
Mon Mar 01 2010, 06:38AM
AmonRa Registered Member #2704 Joined: Mon Mar 01 2010, 04:48AM
I own one of those coils. Having no prior experience with coiling but a good amount of experience with electronics, it has proven to be a great learning experience to say the least. First off, the blue acrylic case is expertly machined and constructed; it's really sharp. The primary and secondary came pre-wound. The toriod is decent; better than anything I could have put together myself. I did have to re-drill the mounting hole as it was off-center for some reason. The PCBs are well done and the manual well written.
I had 4" streamers on the first light; but after tinkering with the tuning, and adding another 10nF cap to the MMC, I've settled in on the optimum tap point and now have consistent 14"-15" arcs from the breakout point. This coil can run without fault for quite a long time and I don't even notice the IGBTs getting significantly hot. I'm very happy with it for what it is. It has found a permanent home on display on my bench at work.
Its a great little kit. Well worth the purchase price.
raff
Mon Mar 01 2010, 07:19AM
raff Registered Member #2315 Joined: Tue Aug 25 2009, 02:35AM
nice to hear smile
anyways, how is the inverter electronics powered up? from 110Vac?
lpfthings
Mon Mar 01 2010, 08:59AM
It runs on 12VAC input from a plug pack, which is stepped up inside the coil itself by a transformer.
AmonRa, got any more pics of the circuit/complete coil etc? The pics on eBay are really low resolution and it's hard to see all the small detail.
Cheers,
Dan
teslaguy
Tue Mar 02 2010, 04:17AM
teslaguy Registered Member #617 Joined: Fri Mar 30 2007, 07:29PM
I own one as well. The guy who designs them used to be a member here, but was banned over a practical joke which turned sour. It is by far the best small coil I have ever built. When I got mine the transformer was dead, but I found a replacement online and since then have been incredibly happy. I would highly recommend buying that kit.
lpfthings
Tue Mar 02 2010, 05:39AM
Do you have any pictures of it handy?
I've been lookin everywhere for some pics bigger than the ones on eBay, you can't really see all the small detail in those.
Regards,
Dan
