  • Guests: 37
Timo (40)
01/05 Timo (40)
01/06 Ash Small (63)
01/06 Oatmeal (38)
programmable IC for induction heater
Sun Jan 31 2010, 08:01AM
Avi,
In the timer1 example I see the #include timer1.h line.
I don't see anything including Timer1.cpp which has the code for the methods. How is this getting into the program? Also, where can I find a table explaining all the port constants like COM1A1 and TCCR1A?
I found the timer1.zip file in the PWM tutorial Link2
Avi
Sun Jan 31 2010, 08:16AM
I accessed it by the registers directly.
im only using
#include <avr/interrupt.h>
#include <avr/io.h>
In my case, i am using the timer for input capture.
Nicko
Sun Jan 31 2010, 12:25PM
&height
IamSmooth wrote ...
Avi,
I too have programmed these - the 328 is the top end of a series of AVRs - the 44, 88, 168 & then the 328.
To play with these I made a carrier which has all the basics on it (xtal, filtering etc.):
To do anything at the register level, you will need the data sheet off Atmel's site - I have one in front of me - it's 440 pages long but well indexed and not too bad when you learn your way around it. I print mine in "booklet" form on the big Canons at work, then have them cut & spiral bound into nice A5 manuals (only costs about 5 bucks to do).
If you want lots of advice on this , do look at using the AVRFreaks.net forums - they are really very good.
1264940210 1334 FT83322 Dscn3990
1264940210 1334 FT83322 Dscn3991
The PDIP versions are probably easier to work with if you don't like SMDs, but as there are less pins, some functionality is reduced (PDIP-28 only has 6 rather than 8 ADC channels etc.)
1264940483 1334 FT83322 P1000353
Killa-X
Sun Jan 31 2010, 04:15PM
Just depends. The Arduino has a very easy programming language to it, as with AVR, I program with C. I own an ATMEGA32 and I was able to make a program with 4 buttons. Frequency up/down, duty cycle up/down. And I've used the PWMs also, fading LEDS 0-255.
