  • Guests: 58
Kolas (18)
Dillon4DynamicHarmonics (41)
12/26 buxtronix (50)
12/27 Elliott (35)
12/27 Gratitude (40)
programmable IC for induction heater
Bjørn
Fri Jan 29 2010, 03:03PM
If the signal can be made digital you can use a capture unit that will give you a very accurate time stamp of the transition of the signal. The aurdinio we are talking about has only one capture module so might be troublesome for that. Maybe you could convert the phase difference into a voltage before it is sampled so the sample rate does not have to be faster than the rate of change in the phase. There are hundreds of ways to do it, you just have to find a method that you like.
To show something a lot more capable (but not more expensive): Link2 It is blindingly fast and can do sampling of analog signals at 2 MHz without even involving the CPU. The down side is that the full complexity hits you in the face and the learning curve is quite steep.
Fri Jan 29 2010, 03:46PM
If I were doing this I'd just bolt a PIC or Arduino onto an existing analog PLL circuit. The chip just has to deal with slowly changing DC voltages, because the PLL handles all the fast stuff.
Fri Jan 29 2010, 04:25PM
What I will do is remake the circuit without the PLL feedback. I will tap off the PCA1 output which should XOR the two signals. I can then use the processor to stay right at midvoltage as it wonders around. This should not be hard at all.
Quickie.
My capacitor tank voltage can be over 300-600v for what I am planning. I was going to run it through 100k and then have a pair of fast diodes clamping it. 600^2/100k = 3.6w
Are there fast diodes for this wattage? I was using the N4148, but I don't think they will handle this power. Any suggestions for cleaning this up and not frying my PLL?
Fri Jan 29 2010, 06:09PM
The diodes are only subjected to roughly (600V / 100k) * some low forward drop. So the power dissipated in them is well within their maximum.
Fri Jan 29 2010, 10:25PM
Uzzors,
I guess if the input impedance to the PLL pin is high, the voltage after the resistor would be very low. I should measure it. Does anyone know what the input impedance for the input pins? I did not see it on the datasheet.
Sat Jan 30 2010, 04:50AM
They are quite high resistance wise (probably >1meg with the internal pullups/downs disabled, obviously with the pullup or pulldown resistors enabled the input impedance would be the resistance of the internal resistors), but they do have appreciable capacitance which could cause issues with high frequencies.
Sun Jan 31 2010, 05:56AM
has anyone here programmed the atmega328?
cjk2
Sun Jan 31 2010, 06:04AM
Yes, AVR chips are great to work with and easy to program. Just get/make a programmer and wire a 6 pin IDC connector on your board and connect it to the correct pins on your AVR. See the datasheet to get the pins correct.
http://www.raphnet.net/divers/avrprog/index_en.php
Sun Jan 31 2010, 06:40AM
When doing analogwrite(3, 128) one implements a 50% (128/256) duty cycle on pin 3. The pwm routine is limited to 1/256 resolution. I was reading that the TImer1 has 10 bits of resolution and I saw some low-level routines for doing this. Am I correct in seeing this?
Avi
Sun Jan 31 2010, 07:55AM
IamSmooth wrote ...
me
the 16 bit timer (I think thats timer 1) seems to go at 16000000>>8 Hz with no prescaler as far as i see. which is 62,500 counts/sec with a 16Mhz crystal
