  • Guests: 30
Ivan Kalafatic (17)
10/07 Pyromaniac (34)
10/07 Wavetuner (76)
10/07 jeffomatic (75)
Bigger sparks from DRSSTC
Goodchild
Sat Jan 09 2010, 06:12AM Print
Ok so I have been working on my DRSSTC for some time now it was compleatly built from the ground up.
My question is I think that I could be getting bigger sparks for the power i'm giving the coil currently im putting
in (about 1200VA) and i'm hitting a primary current of about 400A peak and 380A average.
Here is a vid of the coil running at 100uS and 80% of my 240VAC mains power: Link2
the target is 3 feet from the breakout point. BTW IGBTs didn't even get warm on that run.
May be it's just me but I would expect at least 4.5 if not 5 feet from that amount of power. So is there some way to tweak the DRSSTC to get a foot more spark from the same input power? I have seen people getting 6 feet from the same amount of power and the same type of bridge and IGBTs.
Specs of coil:
secondary: 18x4.5 inches 32 gage wire 2250 turns
primary: 12 turns 0.25" copper tubeing 9.75 inches wide x 5 inchs high
coupling: 0.16k
top load: 18x4.5 inch spun toroid
Fo:98KHz
controller: Steve Ward's DRSSTC controller with primary feedback and OCD
power electronics: full bridge of 60N60s IGBTs
power: 120V variac -> 240V step-up transformer->DR
SSTC
Luca
Sat Jan 09 2010, 12:18PM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
Have you tried with a longer ON time and 100% voltage? I think you can push your IGBT wit a higher current...
Anyway, I think that spark lenght also depends in some ways on the size of the secondary coil, wire size, and on the size of the toroid.
Regards,
Luca
Wolfram
Sat Jan 09 2010, 02:56PM
Check out this Link2 thread, particularly the post by EastVoltageResearch.
There is also some more good information on tuning here Link2 and here Link2 .
Anders M.
Goodchild
Sun Jan 10 2010, 04:13AM
Thanks that thread helped a lot I will give this a try tomorrow. cheesey
Bennem
Wed Jan 20 2010, 08:53AM
Hi Goodchild,
Did you manage to tune your coil for longer sparks?
Mel
Goodchild
Wed Jan 20 2010, 03:41PM
Yes I did I stopped at about 4.5" feet because I want to keep the current to a manageable level. This coil has yet to blow a 30N60s or 60N60 and I would like to keep it that way. cheesey
