  • Guests: 52
DRSSTC with different Sound Colors
GeordieBoy
Wed Jan 06 2010, 03:33PM
The pulse-train with PWM applied has a distinct "detuned" or chorus like sound to it. This is because a pulse train with PWM is equivalent to the difference of two detuneds sawtooth waveforms.
If you generate two sawtooth waveforms at slightly different frequencies called s1 and s2, then subtract one from the other to get s1-s2, the resulting signal looks like a PWM pulse train. That's why your PWM modulator has a thick trancey "detuned" sound to it.
Early analogue music synthesisers used to use this PWM trick to get a richer sound out of a single low cost oscillator, without having to resort to using two seperate oscillators.
-Richie,
Reaching
Wed Jan 06 2010, 05:21PM
thats it ^^
Thu Jan 07 2010, 10:01AM
So it's basically an analogue controlled synth?
Killa-X
Sun Jan 10 2010, 12:13AM
May i ask the name of the plugin? So far for me, the 3x Osc channel is the best output...
