  • Guests: 54
Few questions regarding sgtc
Giedrius
Fri Dec 04 2009, 08:53PM Print
Giedrius Registered Member #2500 Joined: Thu Dec 03 2009, 03:29PM
Hello
i'm new to HV elektronics (in english language)
and i have few questions about sgtc
first i am planing to built this TC Link2
i already have MOT and gona go to bui other parts
but i have no idea what does "off-the-shelf choke" stands for and what it does in tc.
next: i have 0,3mm diameter coper vire and gona vind it on 100mm PVC pipe will it be good? like 1200 - 1300 windings, also can i use polyester resin instead of epoxy? because its cheaper and i have about 0,5l in my posses. wont it eat coat on vire?
thanks
Giedrius
Goodchild
Sat Dec 05 2009, 02:43AM
Giedrius wrote ...
Hello
thanks
Giedrius
That would be a good number of winds for a DRSSTC or SSTC but for a SGTC I would use under 1000 winds. As for the polyester resin I don't know if it will work, I have never used it but I do know that polyurethane works well to but not as well epoxy (It's just cheaper).
And welcome to the forum!
Giedrius
Sat Dec 05 2009, 09:38AM
how about that "off-the-shelf choke" ? what is it? and how i can make it?
Sat Dec 05 2009, 10:01AM
Off-the-shelf means something you can buy in a store.
I used four chokes (inductors) meant for filtering power supplies in tube audio amplifiers, they cost about £6 each from Maplin. They were only available in the UK, and they don't sell them any more. I've since dismantled the coil and reused the chokes in a tube amp. smile
I've also seen people use MOTs modified to include an air gap in this circuit. Two or three in series usually does it, any fewer and the rotary gap will suffer from power arcing.
This doesn't really make sense though: if you have several MOTs, why are you building my design? The whole point of it is that it only needs one MOT.
Giedrius
Sat Dec 05 2009, 10:55AM
thanks for explanaition
i have 2 halogen ligts induktors (or something like that, looks like transformer but only with single vindings, no secondary)
they are rated at 40W.
if i canet them in series, can use them insted of that choke in scheme?
thanks
Giedrius
Giedrius
Mon Dec 07 2009, 05:29PM
ok since 2 days ago i posted and got no answers i'm posting again
i have 4 *40W chokes from old halogen laps, will they hold?
Mon Dec 07 2009, 07:55PM
Sorry, I don't know.
(Did you mean metal halide? Even then, I don't know.)
Giedrius
Mon Dec 07 2009, 08:00PM
Day light lamps?
Giedrius
Fri Dec 11 2009, 08:55PM
ok
which secondary coil configuration is beter?
490 turns, 110 diameter, 150 hight
or
1000 turns 50 diameter, 300hight
Giedrius
Sun Dec 27 2009, 10:30AM
does balancing capacitors and rezistors are necessary on diode chains? or can i just use plain diodes without that parts?
